M20 Piston identification 85mm Bore
  • Motorsport1207
    • Oct 2013
    • 66
    Hi, I disassembled a M20 engine and found these pistons with rods, Can someone help me identify these. I have one piston crown that is cracked and need a replacement Thanks Sent from my iPhone using Tapatalk
  • digger
    • Nov 2005
    • 6215
    kinda look like these CP, just guessing though
    http://www.tmwerkes.ca/the-convertib...roker-project/
    • Motorsport1207
      • Oct 2013
      • 66
      Originally posted by digger
      kinda look like these CP, just guessing though http://www.tmwerkes.ca/the-convertib...roker-project/
      Thanks, I need to look for 1 piston Sent from my iPhone using Tapatalk
      • digger
        • Nov 2005
        • 6215
        contact CP with the code printed on them and see if its one of theirs
        • hasa
          • May 2013
          • 308
          Ross ?
          • digger
            • Nov 2005
            • 6215
            Could be these
            • Motorsport1207
              • Oct 2013
              • 66
              Ok Thanks. Opened engine and found piston crown broken. Any idea Sent from my iPhone using Tapatalk
              • digger
                • Nov 2005
                • 6215
                Is that like sand blasted texture? Probably knock with a bunch of pre-ignition
                the answer is a bad tuneup and a knock prone piston design
                • Motorsport1207
                  • Oct 2013
                  • 66
                  Is that like sand blasted texture? Probably knock with a bunch of pre-ignition the answer is a bad tuneup and a knock prone piston design
                  Hi, What do you mean by a knock probe piston design Thanks Sent from my iPhone using Tapatalk
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    There's hardly any angular squish on those pistons - and they have a flat center, not a spherical dish. The m20 is a "knock-resistant" design so they could run leaner than most engines. The angled edge of the OEM piston swirls the combustion gasses towards the spark plug. When the squish band isn't used properly, the combustion can pre-ignite and knock.
                    john@m20guru.com
                    Links:
                    • digger
                      • Nov 2005
                      • 6215
                      The picture above looks quite a bit different in terms of colouring to the first post. Are they the same engine? Almost looks oily
                      • Motorsport1207
                        • Oct 2013
                        • 66
                        First pics is the piston cleaned up. Sent from my iPhone using Tapatalk
                        • zaq123
                          • Jul 2016
                          • 1574
                          looks like pretty bad piston design. Look at that paper thin edge by the intake valve.....probably gets hot like crazy. Is it me or that burned up piston picture has that enfeebled totally burned off/gone.
                          I wouldn't waste any money on getting another one of those....
                          • digger
                            • Nov 2005
                            • 6215
                            The pocket edge is already machined back it’s not burnt away
                            • TobyB
                              • 5298
                              Yeah, but look at the original crown, by the intake valve pocket- I see signs of detonation right over the ring land.
                              OP, I'd ditch all six, based on the 2 crowns you show, and get something that's better suited...
                              sorry,
                              t
                              has broken pistons due to detonation, too.
