Polyurethane motor mounts?
  • lockedinfridge
    • Feb 2020
    • 1
    Hello! I plan on replacing my motor mounts, as the passenger-side mount isn't exactly on speaking terms with the motor. It's just kind of sitting on it, off to the side. That said, I keep seeing polyurethane mounts for sale. How do they compare to the rubber ones, and should I consider picking some up?
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4508
    If the car is any sort of a street car I would not consider poly. There are HD rubber mounts available that give you the stiffness without the extra NHV, I’d snag those.
    I know there will be a line of folks who disagree, I just don’t feel like poly offers much of anything over a good rubber bush.
    • zaq123
      • Jul 2016
      • 1560
      I agree about poly. Had a bad luck with HD OEM e24 mounts. They are stiffer then stock and less pliable therefore get cracked/ripped easier than OEM. I would go genuine OEM with engine mounts for another 20 years of issue free service
      • digger
        • Nov 2005
        • 6198
        OE m20 rubber engine mounts don't last anywhere near 20 years, and OEM ones are even worse
        • zaq123
          • Jul 2016
          • 1560
          Originally posted by digger
          OE ...... don't last ..... and OEM ones are even worse
          my '90 mounts were still in one piece after 25+ years....ugly one piece but still together.
          What r u trying to say? isn't OE and OEM same thing?what do you run?
          • ForcedFirebird
            • Feb 2007
            • 8300
            Quality OE mounts are fine for a street car that sees occasional road tracks, even. When my car was a daily driver, I drove it to the track for HPDE events for about 2 years. It had the same mounts that came with the car (PO replaced them about a year before), and they didn't break until I lent the car to my pops to do his first track weekend - he hit the guad rail at Sebring.
            The endurance race car had them for about 5 or 6 events (costs us modification points for solid mounts) until a driver hit a tire barrier at Daytona. That was about 6 hours into a 14 hour race, the fan hit the radiator (ultimately causing the engine to blow a HG much later). We would still be using rubber if it weren't for the fear of incidents. The solid mounts cost half the points of an aftermarket seat bar including heim joint adjustable links. Kinda backward rule IMO, sway bars decrease lap times far more than engine mounts.
            john@m20guru.com
            Links:
            • ForcedFirebird
              • Feb 2007
              • 8300
              OE is Original Equipment (or Equivient) OEM is Original Equipment Manufacturer (made by or sold by BMW themselves)
              john@m20guru.com
              Links:
              • digger
                • Nov 2005
                • 6198
                no OEM is different to OE. OE is the genuine BMW part, OEM means the manufacture makes OE parts but not necessarily the supplier for the original equipment of the part in question.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  It's so confusing. In the industry, OE is supposed to mean what came in the car from the mfgr as installed on the car when delivered. Once the part is replaced, it's not considered OE, even if the replacement part came from the auto maker. OEM means the same mfgr that made the original part makes the replacement (Febi, Bosch, Bher, Mhale, BMW etc). I tend to use OEM as the description for the part that is exactly the same as what was installed originally (NOT Rein, Uro, Elring etc)...
                  OEM stands for original equipment manufacturer. OE stands for original equipment. OE parts are the components of the vehicle as it's made in the factory – all of the original parts that the car was first built with. Once the car comes out of the factory, everything else is not an OE part.
                  Edit: So if I have it wrong, sorry, but to sway any confusion with clients, "aftermarket replacement" is the term I use.
                  john@m20guru.com
                  Links:
                  • digger
                    • Nov 2005
                    • 6198
                    probably easier to say genuine BMW parts or aftermarket as that's what i'm referring to.
                    in the case of engine mounts the genuine are like $80 and the others about $8 and the genuine are much better. not 10x better but engine mounts are a PITA to change so you want the best and the lowest chance of delamination
                    • citizen_insane
                      • Jan 2013
                      • 216
                      I didn't notice much of an impact from switching from good condition stock engine mounts to 95A poly mounts. The car has a bit more vibration at idle, but otherwise it was indecipherable. It might also be because the rest of the car is already so "race car" that I just didn't notice (car is full poly or delrin everywhere in the suspension). I have heard that the trans mounts make a really big difference in NVH so I opted to run the thicker stock 23711175424 rubber mounts with a reinforcing cup and been pretty happy.
                      • Slybeanx
                        • Dec 2018
                        • 518
                        I second the 95A poly mounts. Did them with the manual swap along with poly trans. A tad more noise but nothing I can complain about. It does make the whole car vibrate at certain RPMs idk why (like 3700 is just a significant increase and then it goes away at 3800).
                        85% of the time i have no idea what I'm doing
                        • cheffy30
                          • Sep 2016
                          • 1159
                          the originals on my 90 are still just fine. sent from hell using tapatalk
                          '90 325i sedan daily driven
                          '85 325e coupe also a daily
