M30 swap
On my M30 swap we used the later model M20 wiring harness on the M30B35. the easiest way is to match the harness to the motronic you're running.
M30B35 = Motronic 1.3 (use the LAter M20 wiring harness and extent some wires)
M30B34 = Motronic 1.0 (use the earlier M20 harness and extend some wires)
Or save yourself the headache and just find m30 5 sp wiring harness.Comment
1974.5 Jensen Healey : 2003 330i/5Comment
I'm using a harness from an 87 325i and I already extended the all the necessary wires. Its just the injectors plugs are kind of out order and just need to verify that.Comment
I'd lay the harness out and the injectors plugs pretty much fall into place. Some may even still have the #'s on them. They will pretty much only reach where they're suppose to go.1974.5 Jensen Healey : 2003 330i/5Comment
After '87 the injectors got put into a plastic housing. In '87 they have the correct ECU plug, and the injector wires are open. Before '87 the ECU plug ans't correct to fit a 179.
I'd lay the harness out and the injectors plugs pretty much fall into place. Some may even still have the #'s on them. They will pretty much only reach where they're suppose to go.Comment
it shouldn't be hard to identify them even with the numbers gone. the #1 and #6 are the longest and the 3 injector connections with the blue and brown temp sensors are obv for cylinders 1,2,3. Im using an m20 harnessComment
Injectors are fired in two batches of 3s. The easiest harness is the one that came on the engine, the e32/e34 harness, will stand by this statement to my grave :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
