TDI swap
  • 2mAn
    Señior Mod
    • 21030
    TDI swap
    I have been toying with this idea for a while. the biggest hurdle I can think of is how to mount it to the transmission. No TDI came in a rear wheel drive setup except for a Volvo, but that transmission was a piece of shit. I'd like to make an adapter plate and mount it direct to the g260. Thoughts?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • evandael
    • Oct 2009
    • 2881
    it'll probably take an adapter plate, custom flywheel, some way to adapt/mount the pilot bearing, and of course custom engine mounts.
    not really that hard, if you have contacts/resources and design skills and the ability to measure. do it!
    • CarsSuck
      • Oct 2005
      • 968
      what about the passat TDi? I thought passats were longitudinally mounted like an audi.
      --Will
      • twolitresix
        • Jan 2013
        • 21
        Not all of them. Also they're fwd or awd, so those gearboxes wont be of much use...
        Also not shure what is takes to convert a cars fuel-system to diesel?
        • moatilliatta
          • 6157
          Put it in an Ix ;)
          JK....
          @Zakspeed_US
          • HippyEarly
            • Jan 2010
            • 320
            I have read a guy that swapped a TDI into is toyota crawler. It probably had a W56 Toyota transmission but it was longitudinally mounted. Been thinking about this for my '80 Toyota longbed DD
            Been with me for 16 years...
            Wish i had more time to play with her
            • 2mAn
              Señior Mod
              • 21030
              Im thinking the hardest part is the flywheel. I think if I can get a custom flywheel from JB Racing (i think thats there name) the rest shouldnt be too hard. I spoke with someone who can connect me with a machinist who can cut the adapter plate for me, I would just need to sketch it. My thought is that if its a stock G260 flywheel but with the VW crank bolt pattern everything else could be OEM BMW. Im not too worried about the motor mounts and the adapter plate doesnt seem too intimidating
              they are, doesnt really change much to make this easier.
              Passats are unique VWs in that they use a longitudinal setup like the Audi's and yes they were FWD & AWD.
              Converting to diesel fueling is easy. Yank out the fuel pump and put a straight pipe in there, though you can also use a low pressure pump like a Carb'd car. Ive done it on my VWs Ive owned in the past.
              ACME adapters makes an adapter plate to mount to a toyota truck transmission and I considered this, but it adds more modifications to the mix. You would then need custom trans mounts, custom driveshaft, etc.
              Ive found a few TDI setups just north of the border for a good price (about how much a good 885 head would cost me) so I am really thinking of going for it. Im buying another car tomorrow to drive around on so I wont need to rush this, but I cant be lazy about it either.
              Right now, my brain is thinking about the flywheel, does anyone have a stock one they can measure? I know the VW one is 210mm so if its close that is a good start
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • 2mAn
                Señior Mod
                • 21030
                ok did some research...
                The M10 flywheels are 215mm so those are close to the factory 210mm VW flywheels, the M20 flywheels are over 220mm. Called JB racing to see if they could cut me a custom flywheel and they said they could, but it would be between $500-$1000!!
                Soooo, I took another look at the ACME adapters and the toyota transmission adapter and flywheel is $595 so thats a LOT more cost effective. Especially when I found a Toyota 5 speed for $107. I think this is the route I will end up going...
                Trying to arrange to go to Canada to get my TDI motor this weekend. we'll see how this goes.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • quickervicar
                  • 1197
                  I like this.
                  • word is bond
                    • Apr 2012
                    • 503
                    Ambitious. Eagerly awaiting the results. Putting it into an early or late model? 2 or 4 doors?
                    diamantschwarz 1991 318is
                    • e30_neverstock
                      • Nov 2011
                      • 283
                      Originally posted by quickervicar
                      I like this.
                      i like this too.
                      Sub...
                      • Sharino
                        • Jun 2005
                        • 186
                        Check out HPA motorsports kit they sell for the Jeeps. They take a VW TDI engine and switch to mounting it longitudinal and works great for them, I am sure something similar can be adapted to be BMW trans.
                        This is a great idea, I would love a TDI E30!
                        www.eurowinnipeg.com
                        www.E30S38.com
                        E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
                        • 2mAn
                          Señior Mod
                          • 21030
                          Its going into an 84 318 coupe that already had a swapped 2.7i into it. The motor is basically toast now. I was thinking of going with a m52, but I will have another car that will be my "fast" car so this will be my economical daily driver.
                          Thanks for the link! I sent them an email, I would love to keep the G260 if I can.
                          I still dont have the motor yet, but I am still working on that
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • Swanny
                            • Mar 2012
                            • 2834
                            Lovin the ambition! Great swap for a dd. torque out the wazoo and crazy good mpgs. Figure it out quick!
                            Swanny!
                            SUCKERS.
                            • ZM Blue Devil
                              • Dec 2006
                              • 13836
                              Paging Mike and Jake from Left Lane Cars, they do a ton of TDI swaps(in VWs) but they also play with BMWs. I bet they could provide valuable insight.
                              Levent
                              %20levent@gutenparts.com
                              Ladies:
