M30 Turbo engine build
  • Cronopoulos
    • Jul 2011
    • 2187
    This is dope!
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • LowR3V'in
      • 4209
      What power did you end up making on the junkyard build?
      • digger
        • Nov 2005
        • 6092
        Originally posted by e30 gangsta
        Otis, the total seal rings, is there a particular reason why you went with the top ring instead of the secondary ring? Is there any kind of particular benefit in chosing the top ring over the secondary ring, when using those total seal rings?
        Never heard anyone respected recommend the gapless second, apparently it unseats the top ring due them to causing a higher pressure between the top and second ring (presumably due to better seal) which lifts the top ring a little more hurting ring seal. Many piston companies use an accumulator groove between top and second ring which is a reservoir so that any blow by the top ring cause lower pressure on the underside of the top ring which helps stop it flutter.
        Most recommend the top be gapless if gapless are used and claim it better maintains the seal and shows lower leak down numbers when the engine has mileage on it. Could be better for reducing oil contamination which is good for E85
        Others say there is nothing to be gained with gapless over a good conventional ring with torque plate hone and bed in process and the gapless wear out faster and better seal is overcome by higher friction (torque to spin short block by hand). Everyone has an opinion on it, those trying to sell you something are usually bias…..so who knows probably depends….
        IMO you probably need to be running a vacuum pump and/or low tension rings of some kind to see any big difference between various rings and the torque plate and hone finish is more important so trust a competent machinist and GTG.
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          sub'd for m30 pr0n :)
          • bmw335isturbo
            • Mar 2006
            • 218
            I am at work and saw this!!!!
            ������ looks to be a good year.
            The m90 I forgot when I get home I can look it up, I just figured some one might be able to help what year/ model did this block come out of?
            Sorry to stomp on your thread. I like where you are going with this.
            Ok I found it. Google��
            1986 335is-1988 335ist -1991 335istsigpic
            • ForcedFirebird
              • Feb 2007
              • 8300
              Always glad to help, Otis. :) Did the other John agree with a main cap hone? Seems like it's a hit/miss if there will be issues from going to ARP and NOT honing but never head of troubles with the bores corrected.
              Not sure how gapless rings would create any more drag, as the side wall touching the cylinder wall is still the same thickness as a standard ring (same amount of ring touching). The ring doesn't have anymore tension on the walls than any other ring, either. They are gapless because there are 2 top rings, one with a groove to accept the secondary compression ring. When laid on top of each other with gaps facing opposite directions, they become gapless.
              I could see where people have issues with second gapless rings and standard compression rings, like you said, if the piston was not gas ported, the top ring would be pushed up/out.
              There is also argument that compression gapless are not as good as standard because they don't let enough gasses to pass through to push out the second ring - but many racers I know of use gapless top rings without issue. I am trying gapless tops in the Pink turbo car as well.
              john@m20guru.com
              Links:
              • Good & Tight
                • Apr 2004
                • 2057
                Yes, in fact a few were ever so slightly out of round. Now they are all perfect..!
                Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                ____________________________
                E-mail Panayiotisx2@gmail.com
                Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                • digger
                  • Nov 2005
                  • 6092
                  most stuff is only hearsay like alot of performance products and so forth.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Yup. Dealing with this stuff for a living makes it necessity to have facts. Hard to argue with results.
                    john@m20guru.com
                    Links:
                    • Doughnut
                      • Oct 2007
                      • 869
                      This is turning out to be a great thread with fantastic information.
                      Keep us posted Otis
                      ///Monstrosity. (OO≡≡[][]≡≡OO)
                      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                      • RagtopE30
                        • Dec 2010
                        • 1869
                        This is awesome! I am looking forward to watching this progress.
                        450whp 524 lb-ft 1988 336ic In progress
                        http://www.r3vlimited.com/board/showthread.php?t=250709
                        • Good & Tight
                          • Apr 2004
                          • 2057
                          My intent was to run stock main bolts but when initial torque down didn't feel right I pulled them out to find this. streeeeeetch
                          • e30m3s54turbo
                            • Jun 2010
                            • 3258
                            How much streeeeeeech?
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              The left one stretched almost an 1/8" over the right one. You can visually see the difference in the threads and the height.
                              • e30rapidic
                                • 2167
                                only 5 years? You sound like me. hehe
                                '87 325ic, powered by S50.
