iron first in a velvet glove the build of my m30b35
  • digger
    • Nov 2005
    • 6200
    is he going to do a aftermarket intake to adapt his kits to the big bore spacing engines?
    • Anthony B
      • Nov 2012
      • 308
      We where going the route of cutting the standard plenum & fitting the ITB slightly further away from the head. Id be working on an enclosed intake to see flow to each throttle as balances as possible. I know he did a fair bit of flow work with the one he now offers for the m20's.
      I'm leaning towards the s38 option as the are spaced near perfect for the m30, & he has successfully fitted up s38 itbs to an m30 in the past
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        sub'd
        • kronus
          • Apr 2008
          • 13032
          there is even an adapter plate already out there for M30 to S38 ITBs.
          cars beep boop
          • Anthony B
            • Nov 2012
            • 308
            Is that the Paul Burke one? I've tried finding them but they appear to sell once in a blue moon.
            If it comes to it I will measure up an adapter & try my hand at machining it at home, gives me an excuse to buy a milling machine(Might have to give more reason to my other half)
            • kronus
              • Apr 2008
              • 13032
              I don't know if paul makes them anymore, but a set is usually for sale on UK or DE ebay.
              edit: here
              cars beep boop
              • Anthony B
                • Nov 2012
                • 308
                edit: here
                You are a Gentleman & a Sir, I'll have a look at them now, hopefully they will post them to Aus
                • Anthony B
                  • Nov 2012
                  • 308
                  Pulled down my head today surprised with how clean it was though there was minor scoring on the cam, & wrapped up my cam to keep it safe
                  Taking the rocker arms to get treated this Thursday
                  & here is the details to the cam for anyone wondering, ignore the m30b25 on the sheet it's most assured for the b35
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    Very cool.
                    ACS S3 Build / Dinan 5 E34
                    • LJ851
                      • 7919
                      edit: here
                      I port matched a set of these for jb325is.
                      Lorin
                      The M30 is God's engine.
                      • Anthony B
                        • Nov 2012
                        • 308
                        Will be getting them port matched much like your work Lorin, should have the s38 ITB in 3wks time(would have been sooner but got my bank card skimmed & they cleaned out my account tad frustrating).
                        Ordering the adapters tomorrow, & getting an ECS list together of parts to order, along with one for IE
                        • Anthony B
                          • Nov 2012
                          • 308
                          Rocker arms are off getting some love, the guy working on them didn't have much nice things to say about the OEM castings. I should see them back this week/early next & I'm intrigued to see the results.
                          I nearly bit the bullet early on ordering valves for the M30 through IE but held off, then realized the e34 m30b35 valves are +1mm oversized from the early motors. Tossing up PPM or VAC options now.
                          Chatting with my old man about my plans, & after that now I'm looking for a spare short engine to tear down;
                          PPM rod & piston combo 11.0:1 comp
                          New rod & main bearings
                          Sort oil pump/nut
                          Ahhh so much for a budget....... On a plus the current m30 in my car will end up swapped into my GF 89 318i coupe so its a 2 birds 1 stone approach(this lets me justify the cost of the swap, don't find flaws in my logic)
                          • digger
                            • Nov 2005
                            • 6200
                            speak to rama or local head guy he might know a local source for valves. VAC used to use Manley valves dont know if they still do. Also PPF sell valves doesnt say sizes but can contact Andreas
                            • Anthony B
                              • Nov 2012
                              • 308
                              So the PPM option is 47mm intake(+1mm intake) & 39mm exhaust(+2mm). Can I ask who did you head work? Your m20 build is a work of art, I'd like to get the head work started sooner than later & worry if I leave it till August when Rama is back in Aus I'll be cutting time plans down to the wire
                              • Anthony B
                                • Nov 2012
                                • 308
                                Small update I got my rockers back from being peened, he also crack tested & radius-ed some of the edges to remove stress points.
                                Picking up the s38b36 itb's this weekend, & dropped my rocker cover & cam case of to get painted/hyro dipped. Feels good to get stuff crossed off the list.... & then I add more
