Honda K24 swap interest?
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    #526
    That's great! are there any mods to this engine other than the Z3 head? (and your intake/exhaust?)
    Originally posted by priapism
    Originally posted by shameson
    • KMiata
      • Mar 2018
      • 43
      #527
      No, all OEM stuff. I would have just used a K24A2 head but I didn't have one available and I found this K20Z3 head for $300 so I grabbed it. Externally it's the same dimensions so we were still able to build our swap parts around it as though it were a full K24A2 longblock. I have some Drag Cartel 3.2 cams I'd like to throw in eventually, which should put us over 250whp.
      David Calzada
      KMiata Inc.
      KMiata.com
      • 2mAn
        SeƱior Mod
        • 21049
        #528
        Awesome
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • sange
          • Mar 2020
          • 2
          #529
          This was just a week ago, so I think the answer is yes but with no firm timeline
          Thanks, didn't see that. I am definitely waiting for an e36 swap kit!
          • SteveDee
            • Feb 2020
            • 3
            #530
            Kmiata
            would you sell me a set of mounts? I'm looking to get started in the next 6 weeks
            • KMiata
              • Mar 2018
              • 43
              #531
              Originally posted by SteveDee
              Kmiata
              I don't expect to have mounts ready quite that fast, but we will have some available this spring. Currently we just have the single prototype set, which we will be thoroughly testing this March. After that we will begin production.
              David Calzada
              KMiata Inc.
              KMiata.com
              • The Dark Side of Will
                • Jun 2010
                • 2796
                #532
                Originally posted by KMiata
                We got the car on the dyno last night! Our very simple OEM combo made 234whp, 190wtq, rev limiter at 8600 rpm, although we'll probably shift at 8300 on track. It's a K24A2 bottom end, with a K20Z3 head. The K20 head flows lightly better than the K24 head and is worth less than 5 hp on this engine, but it was what we had available.
                I took it around the business park afterwards and it's a riot. Oil pressure was constant at 90+ psi. The AKG engine mounts also feel amazing. It feels like a factory car. Power steering works like stock and feels perfect. Overall I'm thrilled with our execution of this swap, I don't think it could have come together any more nicely. Here's a link to the dyno video on our facebook page.
                Click image for larger version Name:	IMG_7552.jpg Views:	0 Size:	56.4 KB ID:	9909232
                Looks like the VTEC changeover could go up ~200 RPM.
                • rover215
                  • Jan 2018
                  • 49
                  #533
                  KMiata- does your e30 have a working dash (either stock or aftermarket)? Would love to keep it looking original but it's not a big deal. Wonder if the TSX cluster would fit in the stock location.
                  • Fucatypr
                    • Dec 2016
                    • 108
                    #534
                    our harness uses the stock cluster and everything works like stock
                    1993 BMW 850ci factory 6 speed
                    1992 Honda Civic Hatch, built B16, turbo, and nitrous
                    1989 BMW 325i, f20c swap
                    1989 Honda CRX, built LS/vtec, turbo, and nitrous
                    • rover215
                      • Jan 2018
                      • 49
                      #535
                      PERFECT! Where's the info on how to buy it? I follow your YouTube channel, too, and love those red and white e30's. How about engine mounts?
                      • SteveDee
                        • Feb 2020
                        • 3
                        #536
                        I might be able to hang on. How much would you expect to sell them for? Motor and trans
                        • Fucatypr
                          • Dec 2016
                          • 108
                          #537
                          we are doing a small test run of the production mounts in 2 weeks or so and the harnesses are in production now.
                          • JonJonE30
                            • Feb 2020
                            • 9
                            #538
                            Kmiata, what trans are you guys recommending? The Honda 6spd, or bmw zf’s from e36/e46? Will you have trans mounts/driveshafts for a few common choices? If so could you let us know. I’m waiting for more details to start planning what supporting parts to buy.
                            Was there differences in the ka24a2 and z3 fitment? Both need oil pans I’m guessing and you will support both? Is either of the two preferred for our application fitment wise?
                            Thank you!
                            • KMiata
                              • Mar 2018
                              • 43
                              #539
                              Our harness is plug and play and it works with the stock cluster, everything functions normally. The wiring in these cars is thankfully quite simple.
                              Thank you!
                              The K series 6-speed trans is a FWD gearbox, so that's out. For most applications, I'd recommend a Getrag 260 or ZF 5-speed. We have a ZF 5-speed and 3.73 rear end in our car currently, and the gearing seems like a good combo for such a high revving engine. If you stick with a 5-speed, then no custom driveshaft or trans mount is needed, so it keeps things simple. We may eventually make some parts to make it easy to run an E46 ZF 6-speed as well.
                              I have a track weekend booked at NCM for this weekend, so I'm going to put a bunch of hard laps into this thing and monitor temps and oil pressure. But so far it's been great on the street. We are installing our roll bar this week, and I'm getting a proper race alignment done on the car today too.
                              David Calzada
                              KMiata Inc.
                              KMiata.com
                              • rover215
                                • Jan 2018
                                • 49
                                #540
                                And still running the "2002-2004 RSX Type S harness from a K20A2, or 2003-2006 Honda Element manual harness" depending on which engine management we choose to use?
