Honda K24 swap interest?
  • rzerob
    • Jun 2013
    • 2315
    #556
    Originally posted by Andrew325is
    This is really interesting. What concerns me about these custom swaps though is the ease of getting replacement parts. For example, let's say there's a limited run of conversion parts made. Then down the line you crack the oil pan and you're out of luck. So here's my suggestion: Make the oil pan a 2-piece like on a stock E30 4-cylinder engine and make it so the lower pan is an off-the-shelf item, such as the M42 lower pan. That way if you break it, which we know will happen on lowered E30s, you can quickly get a cheap replacement. So that's why my preference always goes to engine swaps that use off-the-shelf parts.
    Or just buy a skid plate or include one in the swap kit.
    • agile30
      • 832
      #557
      I think we have been tarnished by constantly dealing with low oil pans. Maybe the swap will actually allow ample clearance with their pans so we wont have our normal past issues.
      Originally posted by Good & Tight
      It takes real man to mount a big woman, all you haters are just scared boys.
      • varg
        Florida Turbo Man
        • May 2014
        • 3418
        #558
        Just don't make the car so damn low. Being low enough that the oil pan is constantly at risk is silly and it compromises handling, especially with the E30's primitive rear suspension. Or, as above, get a skid plate.
        IG @turbovarg
        '91 318is, M20 turbo
        • Rev Run D
          • Feb 2013
          • 392
          #559
          https://www.youtube.com/watch?v=TW92DM8nQtQ antipurist got a new video up.
          • agile30
            • 832
            #560
            Kmiata made a post today that they are finally finished with track testing their kit. The do not have availability just yet; but this is an awesome step forward.
            • Zambuzan
              • Nov 2017
              • 434
              #561
              Curious to see how the ZF will sit in the e30 chassis with the KMiata engine mounts...
              Depending on the fitment we may very well be able to maintain the stock e30 trans cross member, shift carrier, selector joint, 187mm rod, whole e30 driveshaft (minus trans output flange and guibo), etc. that most of us probably already have. If it reaches this level of plug-n-play then it might be more affordable than a thorough 24v swap...
              "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
              • Rev Run D
                • Feb 2013
                • 392
                #562
                Denver Beer & Oil enter the market!
                • Shangsta
                  • 1485
                  #563
                  I saw this and I am very excited.
                  :shock:
                  • DEV0 E30
                    • Oct 2004
                    • 8893
                    #564
                    Exciting times.
                    • Shangsta
                      • 1485
                      #565
                      We need updates, i need a kswap in my life
                      :shock:
                      • rover215
                        • Jan 2018
                        • 49
                        #566
                        I saw Antipurist have engine mounts, crossmember, and engine wiring harness coming out as a kit (via Instagram). I asked if the mounts would be compatible with my K24, but naw- wrong mounting holes.
                        • Rev Run D
                          • Feb 2013
                          • 392
                          #567
                          88 likes, 23 comments - 625Inc (@625inc) on Instagram: "Who is ready for some F20c kits?"
                          • Shangsta
                            • 1485
                            #568
                            Originally posted by Jaker
                            I'm well on my way to a K20 with twin scroll EFR7163 swap into my E36. I'm using the KMiata transmission adapter kit with a ZF.
                            Awesome. The e36 is a great platform for the kseries. I recently deleted my instagram but I was following a guy in europe with a turbo k20 e36. He took it on the nurburgring and it looked like a riot
                            :shock:
                            • Shangsta
                              • 1485
                              #569
                              Just receive an email from kmiata with this to say about the kwap:E30 K swap parts and other big changes!
                              It's no secret that we're now expanding beyond the Miata chassis. Expect a big announcement next month about some exciting changes taking place.
                              We've been getting constant emails and phone calls about our new E30 K swap packages, so here's an update:
                              • We've been thoroughly testing our K24 swapped E30 at tracks all over the Midwest, including NCM, Gingerman, Putnam Park, and Autobahn.
                              • Since the car is fully sorted and way too much fun, we've already begun production on swap parts!
                              • Expect an official release of this product before the end of the summer, which will include all details, pricing, and availability.
                              :shock:
                              • Fucatypr
                                • Dec 2016
                                • 108
                                #570
                                no crossmember changes are needed and that picture is of the f20c mounts
                                1993 BMW 850ci factory 6 speed
                                1992 Honda Civic Hatch, built B16, turbo, and nitrous
                                1989 BMW 325i, f20c swap
                                1989 Honda CRX, built LS/vtec, turbo, and nitrous
