oil and air seperator for track days
  • OSAH racing
    • Apr 2022
    • 244
    Playing around with the idea of adding one. The PCV system might be good enough but I am planning to run a 1/2 quart over on track days. thoughts?
  • roguetoaster
    Biggus Tippus
    • 7830
    You'll be okay without it providing you simplify the PCV tract and bypass those multiport splitters under the TB. Our former endurance racer 318is had multiple hundreds of hours on track with a stock type system and stock fill level.
    • bmwman91
      • Oct 2004
      • 3134
      Unless you have bad rings and a ton of blow-by, you shouldn't have issues with PCV oil vapor contamination in the intake. Besides, we have port injection, so the intake valves stay nice and clean lol (reason # 1000 why I hate direct injection).
      Transaction Feedback: LINK
      • OSAH racing
        • Apr 2022
        • 244
        Thank you guys.
        • moatilliatta
          • 6158
          Mann Hummel ProVent 100.
          All engines have blow by, you don’t want oil vapors in the intake, you want a vacuum on the crankcase.
          @Zakspeed_US
          • OSAH racing
            • Apr 2022
            • 244
            "Mann Hummel ProVent 100". ordering one today.
            Thanks Zak
            • ForcedFirebird
              • Feb 2007
              • 8300
              Same. We had up to 3 m20 powered enduro cars at one time. Always ran stock systems, over-filled the crank case by a full quart, remove the oil level sensor/baffle, and use a crank scraper.
              john@m20guru.com
              Links:
              • OSAH racing
                • Apr 2022
                • 244
                Any pictures of how your is done under the intake Rougetoaster?
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  Well, when you find the mess under the intake thread you'll find my diagram from fifteen years ago. Basically, you are eliminating the oddly shaped vacuum splitters under the throttle.
                  • OSAH racing
                    • Apr 2022
                    • 244
                    Found it. thanks
