Interest in Bolt on Turbo kit?
  • jakeb
    • 1909
    #181
    Mock up is done...just need to make the manifold itself. The parts car I was using is gone. Couldn't deal with the stink any longer.
    I will make the manifold and bolt everything up to an engine to show the final setup.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • djmossm42
      • Jul 2012
      • 687
      #182
      Awesome!
      Wheelwell
      Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
      LED Bulb Thread
      R6 LED Review
      • S13_E30
        • 309
        #183
        F...k me, my tax refund is going to be about $750 shorter of what I expected.
        • AE86
          • 272
          #184
          ttt
          WTB: Diamond Schwartz Hood
          • S13_E30
            • 309
            #185
            Any updates?
            • jakeb
              • 1909
              #186
              Not much right now...working on other things at the moment. Soon I should be able to make the manifold.
              • Vivek
                attention whore/retard/bitch
                • 6167
                #187
                Updates?
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • jakeb
                  • 1909
                  #188
                  Will be working on the manifold this afternoon as long as all the tubing came today. Lots of other projects going at the same time. I will update as I have progress to show.
                  • S13_E30
                    • 309
                    #189
                    So quick question. After this first kit is made how will you start producing multiple kits? Will you be piecing all of them or are you going to have someone else piece them together?
                    • jakeb
                      • 1909
                      #190
                      I will make them all myself as they are sold.
                      All the bends/parts got here today but later than expected. I was able to get the new collector together but no pictures yet. I'll post an update when I have more to show.
                      The manifold will be a 4-2-1 with cylinders 1-3 together and 2-4 together. Sort of a tri-y manifold.
                      • Balkanac
                        • Apr 2011
                        • 50
                        #191
                        Im glad you are willing to ship to Australia, im interested in one too.
                        Here we have access to 98 octane fuel, would it be possible for the kit to be tuned to run on 98?
                        1991 BMW 318is Brilliantrot
                        1998 Jeep Cherokee TD Black
                        • jntar
                          • 459
                          #192
                          Your 98 is the same as our 93 here in the states.
                          M42 turbo build.
                          http://www.r3vlimited.com/board/showthread.php?t=301330
                          • jakeb
                            • 1909
                            #193
                            Some progress on the manifold. Trying to make it so it is VERY tight to the engine to allow for AC room and also easy to reproduce.
                            routing for cylinder 2
                            routing for cylinder 4
                            I am still not 100% sure on how 1 and 3 will look....
                            Either cut this T and place in here
                            Or put the T here...
                            Runner 3 will then loop up and over #2
                            I will fully make runner 2...tacked all up. Then work on #1.
                            I wasn't very sure how I was going to route everything but this setup should work well.
                            • torell
                              • Dec 2012
                              • 8
                              #194
                              that round holes in the manifold are on purpouse or just for welding time and then will be ovalised?
                              • jakeb
                                • 1909
                                #195
                                The round hole matches the round of the pipe. The side that touches the head will be ported to fit to the port in the head.
                                More work done on the manifold. Entire thing is tacked today. Needs to be sandblasted...and fully welded.
                                sorta out of focus but just to show how tight everything is tucked in.
