Interest in Bolt on Turbo kit?
  • S13_E30
    • 309
    #211
    Any Updates?
    • jakeb
      • 1909
      #212
      Everything for this kit is off to the coater. Once I have it all back it will be assembled on an engine for some pictures and then sent off.
      These will never really be "Mass produced." They will be sold on a kit by kit basis...built to order.
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • Vivek
        attention whore/retard/bitch
        • 6167
        #213
        Awesome, so the first kit is nearly ready to go? I can't wait to see some feedback on it.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • getouth
          • Jan 2010
          • 3343
          #214
          ^^ same here ....mostly concerned about the reliability issue.
          FEEDBACK:
          http://www.r3vlimited.com/board/showthread.php?t=316212
          BMWCCA #398608
          IG @yagayo38
          "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
          • JonnyOg
            • Sep 2012
            • 191
            #215
            You should dyno the e30 with the turbo kit when its all bolted up.
            Edit: also what diff would be best with this setup?
            • Vivek
              • 6167
              #216
              Was wondering this too. I'm thinking probably a 3.73 but I'm probably gonna use a 4.10 for better acceleration.
              • jakeb
                • 1909
                #217
                I would stay with the 4.10.... Diff choice really matters on the use of the car. DD, autocross, track, etc. Yes with the turbo a lower diff you can stay in it longer....
                Picking up the manifold from being ceramic coated tomorrow. Then pics of everything mocked up on the engine...then packed up for the buyer.
                Ported the waste gasket today to stop any boost creep. The flapper is a lot bigger than the hole.
                Mark showing where the flapper hits.
                Opened up about 3mm and smoothed out
                • Vivek
                  • 6167
                  #218
                  Looking good. Is the buyer on r3v/active in this thread? Also, one last stupid question that I know you won't like (don't worry, I wouldn't do this for quite a while, probably not before throwing a rebuilt/refreshed engine in there) but can the rod on the wastegate be adjusted to change the amount that it opens?
                  • jakeb
                    • 1909
                    #219
                    He is on R3v but hasn't really posted in this thread.
                    You can add a manual boost controller. But with more boost the tune will need to be different.
                    • jakeb
                      • 1909
                      #220
                      Loosely put together on an engine on a stand..
                      By pass valve
                      Oil return fitting...this fitting has an O-ring and nut for the inside. Kit will come with the drill bit to drill a hold in the pan. This would be a good time to drop the lower pan and make sure there are no loose bolts holding the upper pan on...commong m42 issue.
                      • Vivek
                        • 6167
                        #221
                        Looks amazing! I can't wait to get mine, I have most of the money and ill probably be PMing you shortly, Jake. I love the black charge pipes and couplers, the whole setup looks very OEM (other than maybe the filter).
                        • Threehz
                          • 1480
                          #222
                          Droool....
                          Different strokes for different folks.
                          • AE86
                            • 272
                            #223
                            Originally posted by Threehz
                            Droool....
                            ditto
                            WTB: Diamond Schwartz Hood
                            • Dj Buttchug
                              • Jun 2010
                              • 7671
                              #224
                              i see this progress and I approve. Im not really a fan of the long intake tube tho.
                              Turbo M42 Build Thread :Here
                              Ig:ryno_pzk
                              I like the tuna here.
                              Originally posted by lambo
                              • Larzzz
                                • Jan 2013
                                • 531
                                #225
                                Damn. Wish i had some money!! If and when i get enough i will be sending you a PM!!
                                1991 318i Slicktop - Sold
                                1991 325ix - Sold
                                1997 Estoril M3 Coupe - Sold
                                1986 325es - RIP
                                1997 328is - Sold
                                1995 Avus M3
                                instagram @MattLarzz
                                //M42 GOON-SQUAD
                                http://www.r3vlimited.com/board/showthread.php?t=281596
