Interest in Bolt on Turbo kit?
  • Simon S
    • Oct 2004
    • 3758
    #136
    ah, cool. I was hoping someone would point out the flaws of my ignorance.
    I like learning things.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Vivek
      attention whore/retard/bitch
      • 6167
      #137
      So what would a decent exhaust setup be? Would 2.25" (stock size) from the downpipe to a high flow muffler be acceptable?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • JonnyOg
        • Sep 2012
        • 191
        #138
        I'm still stoked on this kit, I'll have the cash ready soon, but I'm also curious as the what exhaust we should run. Isn't the tune somewhat dependent on what exhaust we are running?
        • jakeb
          • 1909
          #139
          A turbo LOVES the lack of back pressure. It helps it spool faster. A stock exhaust with a different muffler probably really wouldn't be too bad. But a good setup would be 2.5" back through a couple of straight through mufflers or glass packs. The turbo itself will quiet things down and two glass packs will end up with a quiet setup (if that's what you want).
          The plan is to mock up the kit (at least turbo and intercooler placement next Friday when I have a day off.) Pictures will be posted
          www.classicdaily.net
          1970 m42 swapped 2002
          1985 LS1/T56 Swapped e28 (557e)
          www.blunttech.com - For all your parts needs
          Follow me on Instagram for constant build updates @classicdaily
          https://www.facebook.com/ClassicDailyLLC
          • Goat
            • Jan 2013
            • 3
            #140
            I'm interested
            I'm interested as well. Would like to see finished results first though.
            Just to be clear: this would be a bolt on kit for a stock M42 on an E30 keeping AC and power steering right? Suitable for a daily driver? Includes all required parts (except a more free flowing exhaust is recommended, but not included) is this correct?
            Also, would my sock radiator and cooling hold up?
            • jakeb
              • 1909
              #141
              Yes it will be a bolt on kit to a STOCK m42...yes keeping ac and power steering. Your stock radiator will be fine.
              Hoping to start on it next friday.
              • WhatWentWong
                • Jun 2008
                • 265
                #142
                My pants are tight in anticipation.
                Of course, please as much as possible not cut anything behind the front valence if you don't have to in order to fit the IC.
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  #143
                  well fuuuu. maybe ill buy one just to support all this. After all I have one NA m42 left
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • evol911
                    • Dec 2012
                    • 17
                    #144
                    Didn't see this posted on 2002 faq. Any info on the 2002 M42 swapped cars? I'm interested but this is a half a year out for me. If this is a one time deal, I might be better off piecing my own together down the road.
                    But I will be ordering mounts soon... finally...
                    • djmossm42
                      • Jul 2012
                      • 687
                      #145
                      This is getting very exciting, can't wait!
                      Wheelwell
                      Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
                      LED Bulb Thread
                      R6 LED Review
                      • jakeb
                        • 1909
                        #146
                        I am going to do my best to build it to limit any cutting of the valance. More than likely if you want to keep AC a smalllll bit of the inner valance is going to have to come off. Just so you have room for a pusher fan as well as the AC condenser. I can always make the intercooler mounts adjustable so if you were not keeping AC you could move the intercooler in closer.
                        haha, don't want that NA m42 to feel left out...
                        I didn't post this on the FAQ because right now the bolt on kit will be based around an e30. The 2002 kit is possible (have already built one...and have a jig for the manifold) but the rest wasn't jigged. It will be coming eventually tho....
                        The kits will be available after this first one. Each kit will be built when ordered.
                        thanks
                        • decay
                          • 5637
                          #147
                          Sorry if this has already been asked, I didn't see it if so-
                          Will you sell components? Might want to use your mani/downpipe, but not the intercooler, have other plans for that. Order could look like "manifold, downpipe, turbo, injectors, tune".
                          past:
                          1989 325is (learner shitbox)
                          1986 325e (turbo dorito)
                          1991 318ic (5-lug ITB)
                          1985 323i baur
                          current:
                          • jakeb
                            • 1909
                            #148
                            Yes once the kit is built you will be able to buy JUST certain parts of it.
                            • decay
                              • 5637
                              #149
                              Glad to hear it. Hope this works out well for you, Jake.
                              past:
                              1985 323i baur
                              current:
                              • jakeb
                                • 1909
                                #150
                                Parts car is in the garage and on the lift....
                                extra junk m42 will go in tomorrow....and square away the turbo placement.
