More...
Interest in Bolt on Turbo kit?
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC -
It's possible to change springs in that wastegate, right?The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
I would just go for a log manifold with this low of a power goal. Will make things more tidy, and will have faster response.
The way the runners merge is not so good. I think this manifold will actually be about the same as a log performance wise. At least make a log one too and test them back to back. Might save a huge hassle and lots of space! If you keep this design, ditch the T connections! At least merge the pipes with an angle!-Nick
M42 on VEMSComment
Send me a PM, each kit is made to order. Price is $1700 for the base kit. You can add on wideband, boost gauge, COP setup, etc
You can't really change springs in an internal waste gate. You can run a manual boost controller tho if you want to turn it up a little bit.
This is the manifold we are running on the e21.
Yes a 4-1 merge would be much better but to keep things tight and have room for AC there wasn't any room for a 4-1. The collector was exiting directly on the frame rail. I might be able to make a 4-1 collector using bends rather than straight pipe to save room.
I can offer a log manifold as well but I feel the 4-2-1 even with the Ts is superior.
The e21 with the manifold shown above spools VERY fast and holds 8-9psi solid all the way to the rev limiter.
The manifold is just about all welded up.
https://www.facebook.com/ClassicDailyLLCComment
The e21 had the same turbo and it was getting up to 14psi but it wasn't supposed to be. My buddy with the e21 had his wastegate boost signal from an odd spot. We also ported the wastegate in the turbo housing to help control it. The turbos in my kit will be ported in the same way.
jaywood: I'll repost a complete list soon. But to make it short, the kit comes complete with everything.www.classicdaily.net
The way the runners merge is not so good. I think this manifold will actually be about the same as a log performance wise. At least make a log one too and test them back to back. Might save a huge hassle and lots of space! If you keep this design, ditch the T connections! At least merge the pipes with an angle!Comment
I'm keeping an eye on this. I think my rallycar deserves a turbo.sigpic
1989 Alpine 325is 2dr m50 swapped
Build Thread:
Current ongoing build. Check it out!
1991 318is 4dr rallycross
Rallycross Build Thread.
1991 Alpine 318is coupe - soldComment
Keeping an eye on this. Will definitely place an order once it's built and running on a M42 E30 with the different manifold setup, I'd like to see how it differs from the E21. I was planning on fixing the small exhaust leak and complete my R134 conversion on my E30, but once I order this kit I'll be able to get to the leak and get a thinner fan for the AC to fit the intercooler ;)
Nice work .Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
