Interest in Bolt on Turbo kit?
  • dpmcdonald
    • Feb 2014
    • 243
    #571
    Originally posted by jakeb
    Dyno is getting close. Sent the load cell out to be rewired. HOPING to have it back late this coming week along with the eddy brake controller.
    The test bed car for the MAF will be running in the next week or two.
    Are you planning on doing just one tune for the MAF setup? Or will there be a lower-boost and higher-boost option?
    '91 318is turbo
    • 16v_e30
      • Nov 2013
      • 60
      #572
      Dying to see the numbers and the MAF come to life! And can't wait for winter to be over so I can get back into the m42T. Keep up the solid work Jake
      • MrSlacker
        • 2494
        #573
        Hey guys, Jake's kit is freaking awesome! Unfortunately I have to sell mine before even installing it. Here is a link to my FS thread http://www.r3vlimited.com/board/showthread.php?t=349634
        My Seller/Buyer Feedback
        Performance Aftermarket Parts & Accessories
        • dpmcdonald
          • Feb 2014
          • 243
          #574
          I laid out an entire kit that shipped this past week. Everyone likes pictures so here it is all laid out.
          Here is the current pricing on the kit and other options. The add on prices are only these prices when ordered with the kit.
          Base Kit - $1900
          powder coated Aluminum charge pipes - $100
          Powder coated steel charge pipes - $60 (base kit comes with uncoated steel pipes)
          Ceramic coat on all hot side parts - $140 (turbine, downpipe, manifold)
          Innovate Wideband oxygen sensor gauge - $190
          Boost gauge - $50
          Coil on Plug Kit - $150
          shipping in the US - $70
          Here is a list of what comes with the kit.
          turbo
          manifold (able to keep AC)
          intercooler with mounts
          charge piping with couplers/clamps
          42lb injectors
          by pass valve
          downpipe
          tune
          Best way to get information is to email me at jake@classicdaily.net
          Any progress on the dyno and/or MAF setup?
          '91 318is turbo
          • jakeb
            • 1909
            #575
            Have everything for the dyno to be going...just need time.
            The car that is getting the MAF should be running early next week. I was waiting on getting some parts back from ceramic coat..
            www.classicdaily.net
            1970 m42 swapped 2002
            1985 LS1/T56 Swapped e28 (557e)
            www.blunttech.com - For all your parts needs
            Follow me on Instagram for constant build updates @classicdaily
            https://www.facebook.com/ClassicDailyLLC
            • scoobydo
              • Sep 2013
              • 137
              #576
              Anyone got details on how the IC fittment went on this kit? I have an M30 and using what looks like the same IC. Wonder how you went about mounting it did you cut the valence a bit to bring it as far forward as possible?
              Tks
              • dpmcdonald
                • Feb 2014
                • 243
                #577
                Awesome!! Keep us updated! Would love to see some numbers of the AFM vs MAF when you get them going on the dyno!
                '91 318is turbo
                • brads2002
                  • Nov 2005
                  • 2688
                  #578
                  Scroll back a few pages and look for my post. You do need to cut it but it holds up well.
                  Tks
                  • scoobydo
                    • Sep 2013
                    • 137
                    #579
                    got it in cheers
                    • dpmcdonald
                      • Feb 2014
                      • 243
                      #580
                      Installation progress has begun! All new gaskets and hoses. ARP studs in. The turbo sits nicely on the manifold!
                      '91 318is turbo
                      • brads2002
                        • Nov 2005
                        • 2688
                        #581
                        Looking good! Did you remove the head or just bolt in new bolts? If just new bolts what procedure did you use?
                        • dpmcdonald
                          • Feb 2014
                          • 243
                          #582
                          Thanks! The head was removed for the studs and new gasket.
                          '91 318is turbo
                          • stanz
                            • Mar 2014
                            • 32
                            #583
                            Strong work! Do you have a build thread for this or more pics? Very interested in how it turns out for you. I'm considering getting this kit as well. Are you using an oem head gasket or something thicker? Also, where did you get your skid plate? Thanks and good luck!
                            '91 318is
                            • dpmcdonald
                              • Feb 2014
                              • 243
                              #584
                              Thanks, but I can't take credit for the work. That would be my friend Jimmy at The Snake Shoppe in Portland. He's a pro's pro.
                              OEM head gasket since that is what Jake tuned the kit with and I will be using his tune for at least the near future.
                              Skid plate is from ejnight on these forums. Highly recommended.
                              Here are a couple more pics almost completely buttoned up!
                              '91 318is turbo
                              • econti
                                • May 2014
                                • 1151
                                #585
                                What's airflow like with the cooler there? Good? I was thinking of a shorter (height wise) one mounted low down, where those two long vents are in the valence
