Interest in Bolt on Turbo kit?
  • dpmcdonald
    • Feb 2014
    • 243
    #586
    Originally posted by econti
    What's airflow like with the cooler there? Good? I was thinking of a shorter (height wise) one mounted low down, where those two long vents are in the valence
    The intercooler sits right behind the grill and kidneys and in front of the fan/radiator, so I would assume it benefits from a nice ram air flow as well as a decent pull flow from the fans.
    '91 318is turbo
    • econti
      • May 2014
      • 1151
      #587
      Good point about the fans. I was thinking that cause the bumper is right in front it'd be blocking a fair amount of air. But I guess the fans would make up for that
      • dpmcdonald
        • Feb 2014
        • 243
        #588
        Will be attending a dyno day June 20th. Should be interesting to finally see some real numbers for this kit!
        '91 318is turbo
        • aintnothang
          • 743
          #589
          Hell yeah.
          • jakeb
            • 1909
            #590
            Did some pulls today...boost was a little higher than it should be so numbers are a little higher. BUT things are looking very good.
            Boost is a little high on this one so it is a little leaner than I would like. Need to adjust the preload on the wastegate and/or richen the tune up a bit.
            Same dyno and specs as this graph from a stock NA m42 with TMS chip
            www.classicdaily.net
            1970 m42 swapped 2002
            1985 LS1/T56 Swapped e28 (557e)
            www.blunttech.com - For all your parts needs
            Follow me on Instagram for constant build updates @classicdaily
            https://www.facebook.com/ClassicDailyLLC
            • dpmcdonald
              • Feb 2014
              • 243
              #591
              NICE! What kind of dyno did you get again? Also, why not take it to 6500 RPM? Looks like the power is still climbing!!!
              By the way, I would LOVE for you to tweak it for a nice 12psi tune! :D Are you still planning on the MAF conversion?
              '91 318is turbo
              • jakeb
                • 1909
                #592
                My dyno is an older clayton dyno with newer electronics.
                I could tweek it for more fuel up top and stay at 12psi. I don't expect it would be very hard.
                Yes it was still making power but no tach in car and we were taking baby steps. Swap was just completed.
                • K0nArtist
                  • Apr 2011
                  • 150
                  #593
                  Any updates?
                  • spanish pants
                    • 294
                    #594
                    Great to see someone putting this much dedication into the M42.
                    I would love to do this, but lack of mechanical skill is keeping be back...last time i used a screw driver everyone died.
                    My new E34 525i Sport Limousine Blog
                    http://bmw525isportlimousine.blogspot.com.es/
                    • irish44j
                      • 2763
                      #595
                      interesting......that is higher than I expected. Seems like it might be more than the stock small-case diff can reliably handle?
                      I really want to see someone do a full trackday with this setup to see how everything holds up with the heat, etc.
                      Stage rally/rallycross e30 build/competition journal
                      Track/street e21 build
                      visit Condor Speed Shop
                      visit Motorsport Hardware
                      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3429
                        #596
                        I didn't break mine, though it did make some noise and it felt a bit clunky when I removed it.
                        IG @turbovarg
                        '91 318is, M20 turbo
                        • mabeer
                          • Mar 2012
                          • 43
                          #597
                          I wanted to post my pull here as way of comparison, or rather contrast, to Jake's kit. This is a non-turbo (for the moment)+1 overbore M47 crank stroker with a head by Kormann (Shrick cams and gasket matching primarily). It was an expensive build as the M47 conversion tends to be. I ran it up to Jake to Dyno. I'm happy with the build and results but based on pure performance and the $/HP value spectrum Jake's turbo kit blows the M47 stroker right out of the water.
                          Jake's place is beyond cool with enough insane project going on to make your head spin for weeks. After meeting JakeB I'm a huge fan boy and you should be too. Jake, feel free to post a graph of my pull vs. your turbo for a better visual comparison. If you're on the fence I hope this is the push you need.
                          Here's my pull vs. a stock M42
                          • wazzu70
                            • Jan 2005
                            • 1143
                            #598
                            It would be awesome to see a comparison between the M47 stroker and the turbo kit on the same dyno. Its as close to apples to apples as you can get.
                            -Nick
                            M42 on VEMS
                            • jakeb
                              • 1909
                              #599
                              I'll run a report tomorrow and post it.
                              • wazzu70
                                • Jan 2005
                                • 1143
                                #600
                                Thanks Mr Jake. I think it will really highlight turbo is the path for more power and better power per $.
                                -Nick
                                M42 on VEMS
