91 318is, no crank, no prime
  • dickfitzwell
    • May 2014
    • 104
    Originally posted by Dj Buttchug
    does the engine crank? you stated you have zero crank so im assuming no just to clarify.
    Tap the starter and check all the connections to it.
    Also try bump start?
    edit just re read.
    Zero crank, tapped on the starter to no avail
    - 91 318is - let the fun begin
    WTB: Bilstein Sports/Koni Sports - IE3/HR Springs
    • bmwman91
      • Oct 2004
      • 3134
      Do you read 12V between the biggest wire on the back of the starter and ground? How does the ground strap on the starter look? It is grounded through its connection to the tranny bellhousing, so if the engine ground strap on the passenger side is busted, you'll not have much luck.
      If you have 12V there, then it might be that the starter is jammed, and trying to crank it like that will just overheat the coils. You might want to think about removing it and disassembling it to clean it.
      Transaction Feedback: LINK
      • dickfitzwell
        • May 2014
        • 104
        I just went down and tested a few electrical components, here is what i found:
        1) 12V @ main relay point with key in start and without. Continuous.
        2) 12V @ fuel relay with key in start.
        3)12.3V @ starter no key inserted.
        4)12V @ starter with key in start.
        --- both tests utilizing the big strap on the starter (M42 starter, strap on driver side of the starter) and a viable ground.
        5) 11.8V @ fuel pump between pins 1/3 key in start.
        • bmwman91
          • Oct 2004
          • 3134
          Sorry I think I was being sort of unclear. There's a ground strap on the starter that connects the solenoid area to the main body, which is grounded by being bolted to the tranny. The engine is grounded to the chassis by a strap on the passenger side down by the exhaust manifold. Do both look intact?
          • dickfitzwell
            • May 2014
            • 104
            the grounding strap from the passenger motor mount to the frame rail looks intact, albeit a bit ratty though. i'm going to get a new strap put on in place of that in a few. as for the starter, all the wires look to be in good order.
            • Boris3
              • Apr 2007
              • 439
              Starter Fuse (#10?) OK?
              Not sure if this really adds anything different to what has been suggested, but see #2,5,10 in the no start trouble shooting progression here:
              And just in case you need it:
              1990 325i: slippery slope from DD/DE car to SE30/ITS
              1991 318is: raw DD
              2004 330i zhp: civilized daily driver
              • dickfitzwell
                • May 2014
                • 104
                http://www.armchair.mb.ca/~dave/BMW/e30/e30_91.pdf
                Yes, fuse #10 is Ok. I was using the bavauto link earlier and is how i came about the voltage figures seen above.
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3377
                  In any no-crank situation after verifying the battery is good and the connections are sound, you want to check to see if the starter trigger circuit is working. With the key off, jump the starter trigger terminal straight from the battery and see if the engine cranks. If it does, the starter is good and the problem is that the trigger is not seeing any voltage when you turn the key to the start position, if it does not crank then the starter is bad.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • dickfitzwell
                    • May 2014
                    • 104
                    Any good methods to do this with the battery in the trunk? Or are you suggesting jumping it with the screwdriver method or starter trigger?
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3377
                      Yes, that would be the way to do it since you already know you have voltage at the starter.
                      IG @turbovarg
                      • dickfitzwell
                        • May 2014
                        • 104
                        problem solved. for future use of others with similar problems; replaced the starter and like magic sauce she purred like a rabid kitten... #datM42tho
