What preventative maintenance for long road trip with M42?
  • Gerta
    • Sep 2009
    • 2119
    Ryan, Just installed cruise control in the 318is and I have to say that it plus a gearswitch cup holder really are very helpful for a long cruise. If you can swing it you should see if someone local is getting rid of a cruise set up for an airbag car!
    Parts Collector and Former Houndstooth interior junkie.
    • megatron
      • Jul 2014
      • 152
      Sweet! Not sure if I'll have the time to do an installation before I leave, but a guy locally to here, Zimmerman Automotive, runs an completely stocked indoor used E30 parts store, so could definitely get the parts. I'm also contemplating whether to swap the 3.45 small case LSD out of my 318ti into the 318is to get some longer legs for the trip.
      On a blitz right now catching up the order backlog on the cup holders and building some inventory to bring with me on the trip and also making another thing that's going to be uber helpful on the long drive, so not much sleep these days. :)
      GearSwitch E30 Cup Holder available now at http://gearswitch.us
      • spanish pants
        • 294
        Top off the coolant and give'er the beans.
        My new E34 525i Sport Limousine Blog
        http://bmw525isportlimousine.blogspot.com.es/
        • Gerta
          • Sep 2009
          • 2119
          I like the 4.10 LSD in mine ... I dunno if you will need that but hey ... give it a go!
          • AndrewBird
            The Mad Scientist
            • 11898
            This.
            Throw caution to the wind and just go. If something breaks, fix it when it happens. Unless something is known to be bad or going bad (cracked belts, leaking water pump, etc), I wouldn't bother. Makes for a good story if something does happen. It's not the end of the world if something does go wrong.
            • varg
              Florida Turbo Man
              • May 2014
              • 3405
              AAA.
              Whether you have the maintenance up to date or not.
              IG @turbovarg
              '91 318is, M20 turbo
              • megatron
                • Jul 2014
                • 152
                I've got the 4.10 LSD as well. With the 4.10 and 0.81:1 5th gear overdrive on the E30, it's actually slightly longer than 3.45 and 1:1 5th on my 318ti, and I drove that thing from DC to FL and back without too much issue.
                Only worry is those long Texas and Montanabahn stretches where just keeping up with traffic can mean triple digits, but should be OK. Lots of things stacking up so probably won't get to a diff swap, and anyway, there are twisty mountain roads on the route!
                Update on everything else:
                Maintenance records look good, A/C charged up, will change coolant, oil this weekend, putting spare belts, water and a few quarts of oil in the trunk.
                Getting a toolkit assembled, and rigging up one of my 3d-printers in the trunk.
                This is mostly to print iterations of some parts I'm developing while on those long highway stretches. Nothing like live testing car parts on a road trip and printing the iterations while driving. But hey, if something bad happens and I need a part in the middle of nowhere, I guess I could 3d-print a replacement.
                Thanks everyone for the help!
                • econti
                  • May 2014
                  • 1147
                  I actually get better economy at 3000rpm than 2500rpm, so don't fall into the trap of lower revs = better.
                  • Gerta
                    • Sep 2009
                    • 2119
                    Twisties. Good Times!
                    Print yourself a S14 engine ... immediate 4 cylinder upgrade! I'd love to chat with you about the whole 3d printing idea.
                    • Gerta
                      • Sep 2009
                      • 2119
                      Originally posted by varg
                      AAA.
                      Stalking your build thread. A guy can dream of turbo when kids out of house.
                      • megatron
                        • Jul 2014
                        • 152
                        Hey guys, just quick update. Made it to Austin, heading out now to San Antonio then to Tempe then LA. Super long haul day today.
                        Beat up on the engine at the Tail of the Dragon for day Friday
                        Running 4000RPM + for the entire day on the highway
                        Got tired and took a nap in the car, but it was crazy hot and humid, so left it running with the AC on. Nap ended up being 4hrs... whoops
                        Car and engine is doing great so far, so thanks everyone for the advice.
                        Only mishap so far is I discovered my elephant nose drain must be clogged. Car usually doesn't ever sit in the rain, but had some rain last night with the car in the hotel parking lot, and came back to a wet passenger footwell. Tested heat, no core leak, so phew.
                        Onto the car wash to dry this out and clear out the elephant ear.
                        • lolcantturn
                          • 4588
                          Glad to hear it's doing a good job - these M42's are much more robust than many people give them credit for. Like others said, if there aren't already signs of something failing (strange noises, visual inspection of belts and gaskets), in addition to regular maintenance, you will most likely be alright.
                          Drove my E30 with about 200lbs in the trunk, a passenger and myself for 3000 miles two weekends ago. Up and down the tail of the dragon hauling it as hard as I can was also included in that trip, did just fine.
                          Originally posted by TSI
                          OEM+
