M42 Cam Gears NLA
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #46
    Originally posted by Dj Buttchug
    M44 engines are going to be the (now current) and future donors for us m42 guys. Best way to go here would be to find a local m44 and grab the whole timing case. Deflection wheel for m44 is better and the updated case will direct swap right over.
    If only the internals were as good
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • bmwman91
      • Oct 2004
      • 3134
      #47
      +1 for the M44 timing case conversion. The 1994-1995 M42 timing case also has the updated guide which replaces the (awful) deflector sprocket. The M44 case differs in that the oil pump rotor is 11mm thick instead of 9mm thick (or something to that effect) so it can provide a higher volume of flow. However, it has no provision for holding the crank position sensor, so you will need a machined adapter. Metric mechanic sells one, I think.
      Transaction Feedback: LINK
      • mike.bmw
        • Dec 2015
        • 1767
        #48
        Is the ebay link that someone provided legit? It says they have 5 left. Are those a direct bolt-on for the E30 M42?
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #49
          Legit but they all say sold out and refund your money.
          • J0dylan
            • Jan 2017
            • 10
            #50
            As per RealOEM
            11311721887
            SPROCKET
            From:09/01/1989To:01/25/2017 (ENDED)Weight:0.578 kgPrice:$47.33
            Superseded by:
            11311727446 (09/01/1989 — 12/12/2012), Bilaterally exchangeable
            Part 11311721887 was found on the following vehicles:
            3' E30   (02/1989 — 12/1992)
            3' E36   (02/1991 — 05/1996)
            Pelican shows the 1887 part as still available, the 7446 part isn't listed anymore. Going to try for it see if they can actually get them, says ships in 4 days...
            • av8drvr
              • 110
              #51
              Originally posted by J0dylan
              As per RealOEM
              11311721887
              SPROCKET
              Superseded by:
              See my earlier post in this thread, I called Pelican on this and they insisted they are unavailable. Post back if you get something different please.
              • Powling
                • Jan 2015
                • 1290
                #52
                Sorry if this has been mentioned before but has anyone tried ordering direct from their dealer yet?
                Steve • Toronto
                1991 318is • Brillantrot
                Build Thread
                • e30s50dan
                  • Nov 2008
                  • 2076
                  #53
                  Yes. Couple dealers!.mine checked to see if by chance any other dealers happened to have them in stock.........
                  ..nothing!!
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • J0dylan
                    • Jan 2017
                    • 10
                    #54
                    Yup NLA from pelican just got the email, I was hoping it was the other part number posted at the beginning of this thread they had said was out of stock. Guess they leave the part listed just to mess with us ahah.
                    Just out of curiosity has anyone actually had a chain skip teeth or other timing issues due to just the cam sprockets being worn, and not due to a worn tensioner, chain, and/or guide being the real problem? My pulleys are pretty sharp looking but the tips are all oil varnish, no wear has happened there in a long time, as in the chain doesn't make contact with the top 1/3 of the sprocket teeth, making me wonder how it could have worn down so much or if the wear stops once it gets to a certain point? Obviously they are NLA so i'm going to have to run it as-is anyhow but it seems unlikely a properly tensioned double row chain would skip teeth on what is still left of the sprocket.
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3376
                      #55
                      Originally posted by ccsdo5
                      doubt it. Sounds like someone should look into machining these if they have a cnc machine ;D
                      Maybe when they're completely unavailable or ridiculously expensive otherwise, because they will be a seriously expensive part machined in small numbers.
                      IG @turbovarg
                      '91 318is, M20 turbo
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #56
                        Does anyone make an adjustable cam gear for these? Could always use those and just degree them to stock or use it as an excuse to get some cams lol
                        • TobyB
                          • 5240
                          #57
                          ...the stock gear is adjustable...
                          t
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #58
                            t
                            Didnt know that it was. That explains why i didnt find any.
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              #59
                              IIRC it's a 3 degree total adjustment.
                              • Powling
                                • Jan 2015
                                • 1290
                                #60
                                Just contacted my local BMW dealer and they stated the part is on back order, but will be in between 7-15 days if ordered.
                                Going to place an order now to see if they do in fact come in, or if they come back and say they are no longer available.
                                Steve • Toronto
                                Build Thread
