Revving the M42 to it's redline, then boom stuttering/sputtering
  • fastestbox
    • Jul 2018
    • 124
    My M42 seems to be pretty healthy, but when I get too close to redline/actually at redline to shift, the car doesn't hit it's rev limiter, it instead begins to sputter and have basically no power until I put the clutch in and wait for it to idle. It's fine after that, but does anyone know why this is happening?
    91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
  • e30davie
    • Apr 2016
    • 1788
    Could be anything, but i would start by inspecting the spark plugs and the fuel filter (replace both if you dont know the history)
    • fastestbox
      • Jul 2018
      • 124
      I suppose I should have put this in the original post, but spark plugs have been changed recently, along with coils and wires. Fuel filter has been changed as well.
      Could it be something to do with the engine ground or a camshaft sensor?
      • bmwman91
        • Oct 2004
        • 3134
        What RPM exactly, and is it very consistent or intermittent?
        Transaction Feedback: LINK
        • digger
          • Nov 2005
          • 6198
          crank sensor maybe
          • Nairb
            • 1214
            Check this vid, are these symptoms similar to yours? If so, it's crankshaft position sensor.
            My 1991 318is Progression Thread
            • fastestbox
              • Jul 2018
              • 124
              It happens right before redline, although sometimes it will let me hit redline and it won't bounce, instead it'll just retard the revving and start stuttering/sputtering. So probably around 6500-7000 every single time.
              Originally posted by digger
              crank sensor maybe
              That's highly possible as I had a problem with it before...
              • bmwman91
                • Oct 2004
                • 3134
                Yeah, crank sensor, or maybe an ignition coil on its way out. Also if the fuel filter is plugged up you might be dealing with intermittent fuel starvation at higher flows.
                Pull the spark plugs and check to see if any of them look odd, either sooted/rich or white/lean.
                • TobyB
                  • 5296
                  Check fuel pressure first.
                  Then, in addition to what everyone else said, make sure the AFM tests OK.
                  t
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    t
                    You mean to tell me that this OP shouldn't convert to dual side drafts?
                    • Victell
                      • 1083
                      Is the AFM referenced during WOT?
                      • bmwman91
                        • Oct 2004
                        • 3134
                        Yes, it is still used as the primary input for calculating a base load value. The O2 sensor is ignored.
                        • majdomo
                          • Jun 2018
                          • 449
                          CPS most likely. Had to replace mine 2x, once with aftermarket and finally with OEM. Hasn’t done it since. Exact same symptoms as the video. OEM was fuck-all expensive iirc.
                          Ezekiel 25:17
                          Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
                          The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
                          The ex: E92 335i 6MT M-Sport - Betty
                          The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
                          • Nairb
                            • 1214
                            majmodo I agree 100% on that.. I also got the Bosch part first and my car was no-start whatsoever after that. Once I got the OEM it was 100% back to normal. Unfortunately it has jumped in price, but if you want good reliable performance from your car it's necessary. Worth it for these great old cars.
                            CPS on ecs 19Mar2019: $232
                            https://www.ecstuning.com/b-genuine-...r/12141721504/
                            • majdomo
                              • Jun 2018
                              • 449
                              Right on - wish I’d done this repair myself, but ended up paying the mechanic to hunt down the problem. Almost paid him to replace a perfectly functioning cat, thought it was a blockage in the exhaust.
                              Ezekiel 25:17
