3.64 or 3.73
  • D3R3K
    • Sep 2018
    • 182
    3.64 or 3.73
    I recently swapped my auto 325es to a m20b25 engine with a manual trans. The car currently has a 2.93 and I feel like I can’t get out of 2nd gear on the back roads. I have a 3.64 and a 3.73 gear set. Which would you recommend. The car will be mainly a fun car to drive and maybe a track day or 2 a year.
  • It's Soda Not Pop
    • Jan 2022
    • 877
    3.73 for that power level. 3.73 on the hwy isn't bad either. I also make sure that they are a LSD.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • lukeADE335i
      • Apr 2013
      • 1389
      Agreed - the 3.73 is what the 325i came from the factory with.
      My e30: OEM+ with M30B35
      • Vincenze
        • Apr 2019
        • 1031
        There are calculators that you can use to compare differential ratios.
        • Vincenze
          • Apr 2019
          • 1031
          You can't install a 3.73 gear set into a 2.93 differential.
          • D3R3K
            • Sep 2018
            • 182
            Why’s that? They are both for a medium case diff.
            • jsta1109
              • Jun 2015
              • 172
              The carrier offset changes from 3.07 to 2.79 meaning any ring gears from 3.15 up won't fit. Racing Diffs sells a "differential crown ring spacer" that allows you to adapt but depending on price you'll probably be better off purchasing a complete diff with the correct ratio.
              IG: https://www.instagram.com/josh.stacey/
              Flickr: https://www.flickr.com/photos/133952286@N03/
              • D3R3K
                • Sep 2018
                • 182
                Thank you!
                • 82eye
                  • Jan 2009
                  • 2087
                  that is new to me as well. i've harvested / rebuilt ls units before and changed gear sets. that is good to know about the 2.93.
                  • Panici
                    • Dec 2009
                    • 2527
                    I vote 3.73 LSD as well. Works great with the Getrag 260 ratios.
