whats up w/ my lsd?
  • raafhimself
    • Dec 2008
    • 451
    whats up w/ my lsd?
    when i go hard in first and second i get a rumble from the passenger side. id say it sounds like a rolling-r (like in spanish when rr is pronounced -- alveolar trill for you linguistic peeps out there). it only happens for about a half second or less. ive got a 3.25 lsd from an e28. is this normal? whats the haps?
  • EightiesBaby
    • Jul 2008
    • 268
    bump, i'd like to know this too
    • moatilliatta
      • 6138
      Wheel hop? How old is your shocks?
      @Zakspeed_US
      • slow e30
        • Jul 2009
        • 398
        or weight pulling that side down and causing rubbage
          • 34839
          do you have an LSD additive in your diff oil? they will chatter if you put in straight diff oil with no friction modifiers.
          • hoveringuy
            • Dec 2005
            • 2709
            Is it different when you are turning vs going straight?
            • raafhimself
              • Dec 2008
              • 451
              makes no difference
              thats what im leaning towards, had a mechanic swap the diff for me, not sure what they put in, i wanted a second opinion before i put in some redline
                • 34839
                you can buy limited slip additive from redline. Somewhere I saw how much you're supposed to put in if it's been filled with straight gear oil.
                • raafhimself
                  • Dec 2008
                  • 451
                  alright.... redline 75W90 or 75W140???
                    • 34839
                    75w90
                    • raafhimself
                      • Dec 2008
                      • 451
                      thanky...and whats up w/ the friction additive u mentioned a bit ago.
                      • dreamchasin
                        • 3892
                        i have Royal Purple 75W-90 gear oil in mine. No problems what so ever. 2.93 LSD
                        90 325is alpine2 m50b25 becoming a dorifto car.
                        • raafhimself
                          • Dec 2008
                          • 451
                          are the friction modifiers necessary w/ 75w90? or are they present already/
                            RedLine 75w90 includes friction modifiers, Redline 75w90NS does not. I don't know about Royal Purple.
                            • EightiesBaby
                              • Jul 2008
                              • 268
                              Not to take this topic off track, but I was looking at a couple threads about this same issue and some people were suggesting it could be the CSB. Either way Im getting under the car tomorrow to investigate
