autozone half shafts????
  • dirtrider372
    • Jul 2012
    • 101
    Are the autozone half shafts worth a damn? They're only $60 plus a $75 core charge...
  • reelizmpro
    • 9543
    Sure beats $250 each! What kind of warranty do they have? They sound like a good alternative.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Cronopoulos
      • Jul 2011
      • 2187
      Aren't they lifetime warrantied as well? lol
      Project log -- DIRTY 30
      2.7i * Megasquirt tuned * E85 powered
      • yahh
        • Aug 2012
        • 800
        I heard that they are too short or something like that after searching on e30tech and here. Check the autozone reviews
        s50 86 325e Project
        S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
        Feedback Thread
        • jeffnhiscars
          • Jun 2011
          • 6011
          Keep in mind that that warranty (and you WILL need it) does not cover labor and you will lose your wheel bearings every time you change out the half shafts. Do the math
          Alice the Time Capsule
          • Smelser
            • Feb 2011
            • 633
            how do you loose the wheel bearings?
            you mean when the half shafts grenades it ripes out the bearing as well and it needs to be replaced?
            sigpic1984 318i Total conversion to a DIRT race car.
            Check out our build on facebook @ www.facebook.com/brewstermotorsports
            • reelizmpro
              • 9543
              Sometimes...the inner bearing race pulls out with the axle when you remove it. Seems to happen when removing the shaft from a bad bearing. Perhaps, they fuse together with the excessive heat cause by the friction. I figured the race could be knocked back in if needed...perhaps not?
              88 M3 - LACHSSILBER
              • jeffnhiscars
                • Jun 2011
                • 6011
                My understanding is that when you swap the half shafts you do the bearings since they are highly unlikely to survive. More importantly there are very few happy endings with most rebuilt axles.
                • dirtrider372
                  • Jul 2012
                  • 101
                  Thanks guys. I don't think I'm going to go with cheap remans from a place like autozone. I'm just trying to decide whether I should buy all new boot kits, just spend the money on bmw shafts or oem replacement shafts? what are your opinions?
                  thanks
                  • Cletonius
                    • 2809
                    I would do BMW/OEM.
                    Don't waste your time with a boot kit and rebuild. It's a bitch to repack all the grease and get the little balls back in there, plus there's likely pitting in the races.
                    - Josh
                    1990 325is
                    Need a shift boot?
                    Looking to buy shift boot frames, PM if you have one to sell
                    Here's what happens when you let the internet pick your license plate
                    • e30 gangsta
                      • 3877
                      The napa ones are better quality than the advanced auto/autozone ones.
                      • FLG
                        • Sep 2011
                        • 3165
                        Changed my axles bearings were fine....
                        I've had good luck with feq axles, holding up to 330whp drift car, 100$ each.
                        Sent from my SCH-I545 using Tapatalk 2
                        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                        • mulletman
                          • May 2012
                          • 801
                          I'm assuming feq = First Equipment Quality?
                          • FLG
                            • Sep 2011
                            • 3165
                            Yep, nothing broken and no noises this season so far. Changed them at the beginning of the year, car gets the piss beat out of it.
                            Also no issues with fitment, was just like oem
                            • reelizmpro
                              • 9543
                              I understand that some oes axles are different from the originals as well. The splines are slightly different and they use. 12 pt nut instead of a 6. Almost as if they are shared with another car.
                              88 M3 - LACHSSILBER
