Possible to bolt up a ZF320 to an M20?
  • hopeful
    • Dec 2012
    • 118
    Panici how'd this go? What parts did you end up using to fit the zf into your e30?
    • Panici
      • Dec 2009
      • 2570
      Ended up running the G260 + M20 with an oem clutch setup and slightly lighter flywheel.
      Since then swapped to an M52B28 + G260 and same clutch but using a RHD 7.5lb flywheel.
      And then the current iteration is the M52B28 + ZF320, Spec Stage 3+ clutch, and the same RHD 7.5lb flywheel.
      So I didn't end up trying the ZF320 with the M20 as I was originally thinking about in this thread.
      • hopeful
        • Dec 2012
        • 118
        What driveshaft did you use? Have a build thread/ details on your car? Also, how do you find the RHD flywheel??
        • TobyB
          • 5296
          RHD = RaceHeaD out of Australia...
          Sometimes being punny backfires.
          t
          • Panici
            • Dec 2009
            • 2570
            Used a regular manual trans 325i E30 driveshaft with the G260 behind both engines.
            Now am using an E36 328i driveshaft behind the M52 + ZF320.
            Build thread is in my signature and also at http://e30.panici.ca
