240mm disc on m20 single mass flywheel?
  • varg
    Florida Turbo Man
    • May 2014
    • 3439
    Hmmm... Well I know John and trust his recommendation, and Rob seemed like a good guy to deal with when I spoke to him. I'll certainly speak up if my experience turns out to be shitty, I'm no doormat.
    IG @turbovarg
    '91 318is, M20 turbo
    • blueapplesoda
      • Dec 2005
      • 1904
      Originally posted by nando
      I've heard enough stories of bad UUC service that I'm not sure I'd want to go down that path. Maybe through a 3rd party reseller.
      I ended up getting a hookup for a (used) M5 clutch/pressure plate - it doesn't look like it has many miles on it, so now all I need is an $600 flywheel. lol.
      https://www.turnermotorsport.com/p-2...inum-flywheel/
      Do you have a m20 single mass flywheel handy to lay that m5 stack on top? cause getting a flywheel re-pinned is easy.
      • digger
        • Nov 2005
        • 6216
        I didn't go with uuc because it would be too light for a dd /street engine imo making behaviour with cam and a/c not stable. Also don't like too much rattle which is only going to be worse the less inertia you have
          • 34847
          No, its still in my E30. Want to keep it running until I'm closer to completing the swap.
