Yeah i figured that out
when replacing my wifes clutch in her 97 328i (m52). Dual mass with solid 240mm clutch disc.
So I am now thinking e39 m5 ltw flywheel (240mm obd2), but I need. to find a 240mm spring hub clutch disc that will fit the input splines of the 6spd tranny...
Garey I know you mentioned the e34 M5 spring hub clutch kit, which is kinda pricy at $460bmaparts.com, but it likely not fit the input splines of the 6speed tranny.
