*Updated & only kinda shitty now!* The definitive 5.0/302 swap guide
I guess it's time for me to read through this entire thread.Last edited by Hooffenstein HD; 11-09-2014, 01:33 AM.Comment
Got to look into what heads it has, and if it needs better valve springs. Probably just crappy E7 heads, so I may be looking for some GT40P heads.
Trying to find a cheap distributor and single plane carb manifold so I can throw one of the many 650CFM Holley we have around the place on it. Also need to change the water pump to forward rotation and timing cover to suit.Comment
Unfortunately being in Australia, there isn't an abundance of cheap performance parts available. I'd be looking at $2,500 for decent aluminium heads. Or $1,200 ish for pro comp + machining and assembly with quality parts.
The reason I wanted to switch over to GT40P is because I want to throw some parts at it; headers, roller rockers, cam, intake manifold, valve springs etc and I don't know if what works on E7's will work on GT40/aftermarket aluminium heads when I'm upgrading it sometime down the track. I'd hate to be buying everything twice.
Edit: After more research, it would seem only GT40P heads have specific parts and that's the headers due to different spark plug angle. Too easy. May just get a mild port clean up on the E7's in that case.Last edited by Hooffenstein HD; 11-10-2014, 05:52 PM.Comment
After market aluminium heads are well worth it in my opinion. from memory mine where around $2g for afr 165's and that pedal box is for left hand drive only =(Comment
Back to my clutch problems... would i be right in saying that a 3/4 bore master travelling 38mm is only pushing my 7/8 slave travel only 18mm. somethings not right there hey?
by my calculations my slave should be travelling around 34mm as my slave is 12% bigger than my masterComment
You should be seeing about 28mm of travel from the slave.
(0.750/2)^2 = .140625
(0.875/2)^2 = .19140625
.19140625 / .140625 = 1.36
The 7/8 slave is 36% bigger than the 3/4 master.Comment
thanks!
So yeh, im getting nowhere near that. any ideas on what could be wrong?
I've bleed the system so many times. no air no leaks.Comment
So there's two holes in the clutch fork, right? The rosehill kit puts your pushrod into the hole closest to the bellhousing, yes? If not that might be part of the problem.
I think you need an aftermarket slave cylinder guy. Either that or somehow rig an e36 slave up, I know they can use the stock cylinders.
The other option is to keep the e30 master and switch to a datsun 280z or zx (can't remember which), I think that's the combo e30302 is using.Comment
