My M60 swap
    Just went for a nice drive..sort of. 50+ mph, non stop, heat on full blast, 16" pusher fan wide open, and it would not go below the 3/4 mark on the gauge. Sitting at a stop light is a whole other story..
    I've checked tms, bavauto, pelican and the stealership and the only thermostat I can find is a 95 degree. I'm running the two core e36/8 M radiator, yes I know the three row mishi would be better but I know for a fact that e36 lsx swaps can run this same radiator without problems..very frustrating, I wanted to take it to a big meet tonight downtown but there's no way in hell that's happening now
    sigpic'89 325i
    M60 swap in progress
      Is your temp sensor matched to your instrument cluster? If your cluster is from an 89 325i, get whatever sensor comes stock in an 89 325i. And make sure you have continuity from that sensor to the correct c101 pin.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
        I'm fairly certain it's from my year. It's a brown top sensor. I'll try to borrow an infrared thermometer and check temps
        Took it out to cars and coffee today, I don't think I've ever answered so many questions..every time I would fire it up a crowd would gather around it to see what that noise was coming from
        sigpic'89 325i
          Welcome to the v8-swapped e30 club :)
            When I lived in Pensacola, I had my '87 Pontiac Fiero with Caddy Northstar. A good friend of mine had (and still has) an '02ish Toyota MR2 Spyder with turbo and bodykit.
            We'd go to dinner someplace and park next to each other; when we came out, there'd frequently be a crowd around his car. When I fired my engine up, the crowd would move to my car. :D
              My car should be here tnrw. And I will try to start working on it this weekend.
              I will use the z3m radiator as many have posted it's the best fit.
              323i MTEC1
              Z3 coupe
              E60 M5
                Beware the mishimoto z3m radiator... while it may cool like nothing else out there, it is very, very thick and may cause fitment issues. Clearance may be less than you're comfortable with. I am anyway.
                  Yeah looking at mine, I would have to change engine positions to get the 3 row in there. That would mean getting my selector rod modified again..I just ordered an 85c thermostat (thanks for the pn Ryan) so hopefully it helps. I'm also thinking about getting revshift engine mounts to go with my 75d trans mounts. I'm kinda worried that I'm stressing everything with my rubber engine mounts paired with basically solid trans mounts
                  sigpic'89 325i
                    I need to order a Rad to replace the stock 528 that my set up has. So the z3m stock is the better option for clearence then. I have a 85 so it should drop right in.
                    323i MTEC1
                    Z3 coupe
                    E60 M5
                      You'll get an idea of how poor the fitment is when you see my car. Also, ever been in a car with solid engine mounts? The ones I've been in were super shaky, almost like a vibration. But then again, that's brownie points if you get ladies in the car.
                      Having a solid trans mount isn't gonna hurt your rubber engine mounts.
                        A lot of spece30 guys run poly engine mounts and stock trans mounts. The trans mounting ears will be the first thing to break off in an impact of any sort (accident, curbing on the track, etc...), rending a perfectly good trans useless. Stiffer trans mounts will definitely improve the feel of the shifter, but IMO, e21 mounts with aluminum cups make it about as solid as they'd need to be, and will probably still tear before breaking the trans. That's what I'm running with revshift m60 engine mounts, and it feels great even for a daily driver. The stock m60 rubber mounts were plenty stiff enough, but I needed a little extra space for my e36 steering rack hose connections.
                        As far as radiators, I'm using the Z3M mishimoto, but it's overkill. I have a cheap pep boys 14" pusher, and it rarely kicks on. I drive 100 miles a day, 90-100 degree heat sometimes, in traffic not moving for hours. Never passed the halfway mark. It would run out of gas before passing the 1/2 way mark. You'll be fine with your normal dual core rad once you find the actual source of the problem.
                        Make sure your fan isn't wired backwards. Pep boys fans come set up as pushers, but yellow is ground and black is positive. That got me for a week when I did my swap... I was ready to kill something.
                          I have a lead on a nice 2.93..should I go for it? I was kind of wanting a 3.15 or 3.25 so first and second gear would be retarded..
                          sigpic'89 325i
                            Go for it. 1st gear will still be retarded.
                              Long? Or short?
                                Originally posted by LoneWolf View Post
                                Long? Or short?
                                Short. Retarded as in useless
                                sigpic'89 325i
