My M60 swap
  • JGood
    • Jan 2004
    • 7959
    #271
    Just depends how your c101-x20 adapter is made. The engine harness just has two wires from the sensor to the x20. Just connect whichever you need to your c101. For my 85 325e, it only uses a single wire for the gauge, and it's only a single pin sensor. So I just connected the c101 pin to the x20 pin that had continuity to the pin on the temp sensor plug that the m20 sensor uses.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Jack89i
      • Dec 2013
      • 240
      #272
      Well I just found a lovely crack in my valve cover. That timing cover got smashed in the accident and I guess the valve cover took a little bit of damage too
      The paint on this one didn't come out great anyways
      sigpic'89 325i
      M60 swap in progress
      • Jack89i
        • Dec 2013
        • 240
        #273
        Sorry for the lack of updates, the car is running good. I've been driving it, the clutch seems to hold the power. I got my x5 manifolds modified and on
        I picked up some valve cover covers on ebay
        And got my wires through the firewall.
        A new diff is next and I need to fix my heat issue..it runs at or just below the 3/4 on the gauge..with the fan on high
        sigpic'89 325i
        • jalopi
          • 2370
          #274
          Man, I'm pretty goddamn jelly of how clean your engine bay looks. Mine is dirty as fuck.
          • MJCRO
            • Apr 2012
            • 597
            #275
            Nice!!
            • Old city bimmer
              • Jun 2014
              • 1114
              #276
              just read your whole thread. great to see all the progress you have made. I just bought a 85 with this exact swap but most of all the hard work has been done by previous owner.
              323i MTEC1
              Z3 coupe
              E60 M5
              • econti
                • May 2014
                • 1151
                #277
                What's the weight distribution like with the 8 in the front?
                • jalopi
                  • 2370
                  #278
                  Depending on the v8, anywhere from zero to 50lbs gained on the nose
                  up to 50lbs gained in the center of the car depending on the tranny
                  so really it doesn't change much.
                  • Jack89i
                    • Dec 2013
                    • 240
                    #279
                    ^^^this. Also the v8 sits a lot farther back than an m20 does (four cylinders long instead of six)
                    sigpic'89 325i
                    • econti
                      • May 2014
                      • 1151
                      #280
                      So like 52 or 53 front? That's pretty good. I guess cause it's alu not an iron block.
                      Dammit guys, you're tempting me.
                      • mzollo
                        • May 2012
                        • 120
                        #281
                        very jealous...nice Job man!!
                        • Jack89i
                          • Dec 2013
                          • 240
                          #282
                          Thanks mike! Will you be going back to bimmerfest this year?
                          sigpic'89 325i
                          • Jack89i
                            • Dec 2013
                            • 240
                            #283
                            Nice! I think you'll be pleased with it..What all is left to do?
                            sigpic'89 325i
                            • Old city bimmer
                              • Jun 2014
                              • 1114
                              #284
                              the radiator and cooling system need to be done, need the shift rod extended and exhaust put together. I like the set up you did moving the filter housing to the side to accommodate the top hose.
                              I will post pics of my project when I get home.
                              323i MTEC1
                              Z3 coupe
                              E60 M5
                              • mzollo
                                • May 2012
                                • 120
                                #285
                                I havent decided yet if i can stay with beecher and his buddy again than maybe, but i really want to. My clutch is way to far gone for me to trust it that long on the road. Plus fuck highway with a 3.73.. Too annoying i miss my 3.25
