My M60 swap
  • LoneWolf
    • 402
    #256
    Originally posted by Jack89i
    Damn I ordered one off ebay a few days ago..I have exactly one week to have this thing driving (For the vintage). I found a set of race land coil overs for sale locally but my oil pan is already scary close to the ground. Is everyone running custom skid plates or did we get lucky with m20 skid plate fitment?
    Looking forward to seeing your car at bimmefest Justin.
    Prior to starting my swap I had talked to Red46 about getting a skid plate for the M60 swap.
    We talked about coordinating it after my swap was finished. But maybe you can do it before I could
    • Jack89i
      • Dec 2013
      • 240
      #257
      So I can't get my passenger side exhaust manifolds to fit at all, I'm thinking if I take all the studs out I might can slide it in there. Got my maf and got rid of TCS
      I'm waiting on an e36 328i driveshaft, it is to my understanding that I need a 328i guibo and an e30 CSB?
      I'm still having wiring issues. I've looked at probably six pinout charts and not a single one matches my wire colors for the chassis or the x20..
      It's not looking like I'll make it to the vintage so far
      sigpic'89 325i
      M60 swap in progress
      • Jack89i
        • Dec 2013
        • 240
        #258
        Got it to turn over via the key! Just need to sort out a few electrical problems, sort out the exhaust manifolds and put the driveshaft in
        sigpic'89 325i
        • Zacm829
          • Jan 2008
          • 1919
          #259
          Cutting it close! Good Luck!
          1987 325i-M60b44 swap
          • jalopi
            • 2370
            #260
            Sweet. Git-r-done bro
            • LoneWolf
              • 402
              #261
              Awesome job man. You really moved right along.
              • dirty30
                • 3086
                #262
                There is still plenty of time! I better see that thing at the show!
                • Jack89i
                  • Dec 2013
                  • 240
                  #263
                  Well the e30 didn't make it to the vintage..I still went and had a good time though. Saw some awesome e30s. It will definitely be at bimmerfest.
                  Found these pictures on my computer of the day I got the e30 back in 2010. I was in 8th grade at the time
                  sigpic'89 325i
                  • jalopi
                    • 2370
                    #264
                    Sweet man, I'll look out for your car while I'm there. Either that or you can just find me. Look for a gaggle of haters :)
                    Oh, also, here's a good side road at the tail end of the trip. It's a 20 minute detour, but totally worth it after like, 300 miles of highway driving.
                    • Jack89i
                      • Dec 2013
                      • 240
                      #265
                      My M60 swap
                      Turned out to be a crank position sensor keeping it from starting. Had to drain the coolant, grind off the bolt head and break through a bunch of corrosion to get that bitch out. Fired right up once the replacement was in. I couldn't wait to finish the manifolds to start it up. I was so stoked!
                      sigpic'89 325i
                      • Zacm829
                        • Jan 2008
                        • 1919
                        #266
                        :up:.
                        I'm excited for you and a tad jealous.
                        • Jack89i
                          • Dec 2013
                          • 240
                          #267
                          Cool thanks for the link, and I'll see you there jalopi.
                          Looking forward to see your swap at an nce30 meet zach.
                          I've been driving the car on short little trips around the block. The temp gauge isn't working so I haven't drivin it farther than a mile because I'm afraid of overheating. The temp sensor on the m60 is a two pole and the m20 had a single prong sender. I put a 91 818 sensor on the engine, still nothing. I jumped the two wires on the sensor connector and the gauge maxed out so I believe wiring is good. Extremely annoying, it's killing me not bring able to drive it
                          sigpic'89 325i
                          • jalopi
                            • 2370
                            #268
                            I might be wrong, but it looks like one of the wires is a ground and the other is the power/sending wire.
                            Double check this with someone before I cost you something expensive, but I'd try grounding one of the pins out to the block or something while feeding power to the other pin. If that doesn't work, switch it up.
                            • JGood
                              • Jan 2004
                              • 7959
                              #269
                              You just use whatever sensor your car had from the factory, and make sure the correct x20 wire that connects to the single sensor pin is connected to your c101 sensor wire.
                              This is documented in this forum a bunch of times, should be able to find everything you need with a quick search.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • dirty30
                                • 3086
                                #270
                                Justin,
                                Weren't the pins flip flopped from the V8 plug to the E30 sender? I couldn't remember for the life of me.
