'89 316i E30 LS1 Swap Build Thread
  • jpod999
    • Dec 2015
    • 1401
    #121
    Sounds like you have an awesome car collection, is that somewhat typical for Kuwait?
    OBDI M62B44/6 swap
    Transaction feedback
    - jpod999
    • Q8y_drifter
      • Aug 2009
      • 297
      #122
      Not really. Typical owner here has one, MAYBE two modern cars, in the $30K-40K range.
      That Wagoneer was headed for the scrapyard. I picked it up for about $1,800. Minimal surface rust on the floor board (chassis and body are rust-free) and a perfect LS swap candidate (already have a 5.7 LS1 & 4L65E trans waiting for a donor vehicle).
      Same story with the E30 and cutlass. All in the sub $3K range and neglected. I just hate to see them recycled into the disposable soulless garbage that is today's cars.
      The current car list atm is as follows :-
      1989 BMW E30 - Track car (5.7 LS1 / T56 / Gutted)
      1985 Oldsmobile Cutlass - Future Weekend Cruiser (5.7 LS1 / TH200-R4)
      1991 Jeep Grand Wagoneer - Future Camper / Expedition vehicle (5.7 LS1 / 4L65E / NP241c)
      2013 GMC Sierra 4.8L RCSB - Daily Truck
      2014 Jeep Wrangler JK Sport - Current Offroader
      2008 Infiniti G35 Sedan - To be sold
      Alpine White 1989 E30 Coupe - LS1/T56
      • shiboujin
        • Feb 2006
        • 2791
        #123
        So happy to see this project coming together. With all the emails and stuff, I'm pretty invested meow.
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4496
          #124
          What are the specs on those wheels? 16x8 +20? They look great with the R888s on there!
          • Q8y_drifter
            • Aug 2009
            • 297
            #125
            Yep those are 16x8 +20 on 225mm R888's. It's a VERY tight fit between the shocks and fender. I'm gonna have to roll the fenders are go with 3-5mm spacers all around. I have steering rack spacers to increase angle and the tires hit the chassis before full lock.
            • Q8y_drifter
              • Aug 2009
              • 297
              #126
              I've got the new fan setup mounted and wired up. After a lot of measuring for clearance, the fans I ended up using were Maradyne/Summit dual 12" puller fans with built-in shroud.
              These fit almost perfectly onto the Mishimoto R32 radiator setup I'm running and cover the whole radiator core and best of all they clear all the accessories upfront. Should perform even better than the single 16" pusher I had before. The fans are wired up using a 3-relay setup identical to factory GM setup. The PCM controls the fans through pins 33 & 42 and can operate them in low/high speed depending on ECT.
              Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
              • DER E30
                • Sep 2013
                • 2349
                #127
                I have a maradyne fan set up like that in my truck, no issues at all cooling, good deal
                -Christian
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  #128
                  Thats good to hear. I dont think theres a better option out there without converting to vette accessory spacing and installing slightly larger fan motors
                  • Q8y_drifter
                    • Aug 2009
                    • 297
                    #129
                    Front fenders rolled (still gotta finish up the rears tomorrow), idle issues fixed, fan settings tuned, reverse lockout issues fixed and oil temp gauge wired up.
                    Got my Wilwood F/R BBK along with Lee's install kit. Waiting for brake pads to arrive.
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #130
                      Man this thing is gorgeous,.
                      Sent from my iPad using Tapatalk
                      e30Ls1 Swap IG: 1dirty30
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        #131
                        Thanks!
                        Been busy as hell recently with these two builds
                        Friend's 2001 Jeep Wranger TJ - 5.7 LS1 / AX-15 trans / Stock transfer case
                        and my 1991 Jeep Grand Wagoneer - 5.7 LS1 / 4L60e / Chevy NP241 transfer case
                        • mila325
                          • Sep 2015
                          • 82
                          #132
                          Great project! Keen to see how it progresses and to learn about how the feel is with the manual brakes and BBK... I was going to go the exact same set-up. Keep it up dude!
                          • z28
                            • Oct 2014
                            • 362
                            #133
                            Do you have the part number for the fan?
                            First e30 - 1991 318i 4 door
                            • Q8y_drifter
                              • Aug 2009
                              • 297
                              #134
                              These are the fans
                              • z28
                                • Oct 2014
                                • 362
                                #135
                                Thank you, I just added it to my wishlist.
