E30ls1
  • Reyhan335
    • Nov 2015
    • 700
    #286
    Sorry, we couldn’t find that page
    Got them all connected. New fittings and all!
    Fuel pump is out gonna change it out to the walboro soon.
    e30Ls1 Swap IG: 1dirty30
    • lemansguy
      • Nov 2013
      • 205
      #287
      awesome man! let me know how the walbro install goes. mine was a btch. my stock pump seemed to be different then all the others ive seen online, had to hack my stock setup up to get it to fit together, and it im still not 100% happy with it. I have a feeling im gonna make something more custom down the road.
      '87 BMW 325i - ground control c/o, condor bushings, 16x8/16x9 wheels - SOLD
      '09 MazdaSpeed 3 - FOR SALE
      • Reyhan335
        • Nov 2015
        • 700
        #288
        Early models are different than new models. What year is yours?
        • lemansguy
          • Nov 2013
          • 205
          #289
          mine is a '87 325i sedan
          • Reyhan335
            • Nov 2015
            • 700
            #290
            Creating a list I need to do before I take my car up to Virginia next month to e30whore. We will build the exhaust radiator mount and install fuel line kit up there. But before all that I have to do this
            Easy things. Just gotta find time to do it and knock it all out.
            Also what's the easiest way to clean carpet? I have a pressure washer. Should I just use purple power?
            • 968Reckless
              • May 2013
              • 1095
              #291
              E30ls1
              Medium bristle brush and carpet cleaner. Power wash after. You can dye them too.
              Sent from my beeper
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
              • Reyhan335
                • Nov 2015
                • 700
                #292
                Struts changed. Tailight seals changed.
                The struts were a bitch to change. Should've done them before I did the trunk setup. But oh whatever.
                For some reason I didn't get how to put the bracket for the tranny on... Anyone else do the Garret swap? Got pics of what the mount looks like under the car?
                • Pootis
                  • 636
                  #293
                  Looks to me that you have it upside down and your transmission isn't high enough
                  1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                  COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                  • Reyhan335
                    • Nov 2015
                    • 700
                    #294
                    Spoke to Garrett and he showed me the right direction.
                    Super hyped to see it all mounted up
                    I got a little grinder happy
                    Bimmer....Hurst....?^ whatttttt
                    Thanks to my girl for always helping out and hogging the fans. She cleaned up the shop/storage unit. Looks a lot better
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #295
                      E30ls1
                      Got two tires in and on. Gonna test fit these two in the rear and see if I can go any wider or do I stick to 225/45:16?
                      • Reyhan335
                        • Nov 2015
                        • 700
                        #296
                        Purple power and a pressure washer. The water was so filthy.
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #297
                          I had such a hard time putting the pedals all in. It would've been so much easier without the steering wheel and wires all in my face. I've never cursed so much in my life lol. I was in this position for like three hrs calling out tools I need for my gf to find and bring to me.
                          Also. What fits in this hole? Is it for a vacuum line??
                          Throttle cable came in
                          • sgtskid
                            • 763
                            #298
                            Looking good. I'm interested to see how your throttle cable works. I'll be buying the exact same thing.
                            On your way to VA you should take a detour and swing through Deals Gap. ;)
                            Current: '91 DS M3, '03 TS M3 (6MT)
                            '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
                            Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
                            1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
                            IG: RDE_Fabrications
                            Check us out
                            Or YouTube --> HERE;
                            • jon2681
                              • Aug 2009
                              • 96
                              #299
                              That hole is for pcv line that goes across to other valvecover then to behind throttle body i have catch can before it goes behind throttle body
                              ~original
                              • Pootis
                                • 636
                                #300
                                Have you had your driveshaft made yet?
