E30ls1
  • Q8y_drifter
    • Aug 2009
    • 297
    #451
    Is the battery fresh?
    Alpine White 1989 E30 Coupe - LS1/T56
    • Reyhan335
      • Nov 2015
      • 700
      #452
      Yeah. Freshly charged. The motor is turning over and everything. Just no spark or no fuel.
      Doesn't make sense.
      All the wires are hooked up.
      e30Ls1 Swap IG: 1dirty30
      • Pootis
        • 636
        #453
        How is the starter wired....
        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
        • Reyhan335
          • Nov 2015
          • 700
          #454
          Starter is wired from the power cable of the e30. Ignition is just off a wire and I tap it against a positive terminal to engage it
          • Reyhan335
            • Nov 2015
            • 700
            #455
            • Reyhan335
              • Nov 2015
              • 700
              #456
              Connected the obd2 port and nothing. The ECM won't turn on. There's power on the harness. And relays.
              Relays are clicking. There's power to all the fuses. I checked power on the coil switch and there's power there. But even with the ignition on the obd2 port should work. What am I doing wrong for the computer to not get power
              My grounds
              And one more on the other side from body to block
              • The Dark Side of Will
                • Jun 2010
                • 2796
                #457
                I don't have a pinout in front of me, but basically, you should be able to pull the connector off the ECM, then turn on the key and see +12V at the pins specified in the pinout.
                If not, follow those wires until you find something wrong.
                There should also be a "keep alive" hot at all times +12V wire for the ECM to use to retain idle learn settings and fuel trims. If this isn't supplied, the computer may not turn on correctly when the key is turned on.
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  #458
                  Hold on.. what PCM is that? 97/98 F-Body?
                  The harness needs a 411 or 896 PCM (99+ LS1) since the pinouts are completely different.
                  • Q8y_drifter
                    • Aug 2009
                    • 297
                    #459
                    BTW here's the pin outs for future reference
                    97-98 PCM
                    99+
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #460
                      It's an 01 fbody computer
                      And the motor is a 98 ls1
                      I bought the computer when I thought the motor was a 2001. But then found out Po lied to me.
                      But I found out that the 2000-2001 are better to have on these motors
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        #461
                        97-98 PCM
                        99+ PCM
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #462
                          Wow looks like the Po for the computer lied too.... So now I have a tuned 97-98 ecu? And I need 99+?
                          Does it matter if the motor is 98?
                          • Reyhan335
                            • Nov 2015
                            • 700
                            #463
                            just 2 day shipped a pcm from the PSI harness website. it won't be tuned but it'll turn the car on.
                            NOTE: FOR USE WITH PSI HARNESSES ONLY APPLICATION: 1997-2007 LS and Vortec gen 3 drive by cable and drive by wire engine swaps, and 2007-2018 gen 4
                            • Q8y_drifter
                              • Aug 2009
                              • 297
                              #464
                              It shouldn't matter.
                                • Jun 2010
                                • 2796
                                #465
                                Correct. The PCM and engine don't care about year up to about '04ish.
                                However, the harness must be wired correctly for the PCM (or PCM must be correct for the way the harness is wired).
