E30ls1
  • Reyhan335
    • Nov 2015
    • 700
    #481
    Waiting on jags that run to send me a u joint then waiting on them to ship it from California and then they can start on my driveshaft. I'm thinking 2 weeks ? Then I have to take it to an exhaust shop
    e30Ls1 Swap IG: 1dirty30
    • sgtskid
      • 763
      #482
      I'd be curious how much your driveshaft costs. Mine was probably the single most expensive part of my build. I paid right at $400 from a local shop and that includes the adapter from JTR.
      Current: '91 DS M3, '03 TS M3 (6MT)
      '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
      Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
      1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
      IG: RDE_Fabrications
      Check us out
      Or YouTube --> HERE;
      • Reyhan335
        • Nov 2015
        • 700
        #483
        Ujoint comes from jags that run tomorrow. So I'm guessing they'll start Monday on it and it'll be done Wednesday?
        • jon volk
          • Dec 2004
          • 525
          #484
          I usually just buy my custom driveshafts from Strange Engineering. $275 or so for a 3" chromoly shaft with 1350 u-joints. On lower hp stuff that needs more clearance, I just buy them from Coleman racing. 2.5" steel shaft with 1310 u joints for $180. Jegs sells them and they are available in .5" increments.
          That doesnt include the slip yoke, but you should have that first anyway to get the proper driveshaft length.
          Formerly 666 Fabrication
          https://www.youtube.com/@CouchBuilt
          • Reyhan335
            • Nov 2015
            • 700
            #485
            i just took it to the shop and told them to do it.
            • Reyhan335
              • Nov 2015
              • 700
              #486
              If anyone knows or has a set of the one piece square headlights for the e30 please let me know.
              • Reyhan335
                • Nov 2015
                • 700
                #487
                438.14+111 for u joint
                It's so close to hitting the top. It looks like I'll have to replace all the bushings and raise the subframe up a bit..... Idk
                Going to exhaust shop either tmrw or Thursday... It's a tight fit. Don't worry the lines won't stay kinked like that. Just put it there so it'd be easier for the exhaust guy
                Also thanks to Texas speed they swapped the tune to my new pcm and bought my old pcm.
                • Pootis
                  • 636
                  #488
                  If you just get the subframe bushings with the 12mm riser built in you should be good.
                  1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                  COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                  • Reyhan335
                    • Nov 2015
                    • 700
                    #489
                    I think I'm going to get all new bushings for the rear including that... I've never done bushings tho..
                    • Pootis
                      • 636
                      #490
                      Pretty simple but really time consuming
                      • Reyhan335
                        • Nov 2015
                        • 700
                        #491
                        For someone who's never done it , how long would you think it'd take.
                        Sent from my iPad using Tapatalk
                        • jpod999
                          • Dec 2015
                          • 1401
                          #492
                          Schedule the whole day just to make sure you aren't rushing.
                          OBDI M62B44/6 swap
                          Transaction feedback
                          - jpod999
                          • Reyhan335
                            • Nov 2015
                            • 700
                            #493
                            shit, it's hard to get a full day to work on it when i'm pushing 80 hrs a week at work:/ it'll have to be nights
                            • jpod999
                              • Dec 2015
                              • 1401
                              #494
                              Just spread it out then. Take your time dropping the subframe, it's not really that hard but can be a bit unwieldy.
                              OBDI M62B44/6 swap
                              - jpod999
                              • Reyhan335
                                • Nov 2015
                                • 700
                                #495
                                just when i thought i had a couple steps left, i jump back 7 more.
                                but it's okay. it has to be done anyways..
