M Tech Steering Wheel
  • Ohmess
    • Aug 2011
    • 17
    Where can I find info on the variations of the M Tech Steering wheel and what they are worth. I am trying to figure out if the decoration on my garage wall is valuable.
    I believe there was an M tech 1 for the 80s cars, and two versions of the M Tech 2 (270 and 385mm). Also, I think the number of teeth on the splines were different between the 1 and 2 (or perhaps between the different versions of the 2?).
    My e39 540i6:
    HRE 543s w/Michelin Pilot Sports
    Koala LSD w/ 3.38 Gears
    H&R Springs/Bilsteins/Eibach sway bars
    Zionsville Alloy Radiator and fan
    Authority CAI and ECU tuning
    M5 calipers, European M5 floating rotors
    SprintBooster
    Eurodash & armrest
    Aspheric Mirrors
    V1 Headrest install w/ashtray display
    Lidatek w/custom dash switch
    Saab trunk handle
  • 82eye
    • Jan 2009
    • 2109
    e30 zone lists them along with a classic period tuner and aftermarket wheels.
    • Ohmess
      • Aug 2011
      • 17
      Thx. That helps.
      Do the 285 mm M Tech 1s have different splines for the e30 v the e24?
      My e39 540i6:
      SprintBooster
      Eurodash & armrest
      Aspheric Mirrors
      Saab trunk handle
      • 82eye
        • Jan 2009
        • 2109
        Originally posted by Ohmess
        Thx. That helps.
        some fit some don't. e24 uses both the coarse and the fine spline wheels. later e24s will fit. think the the change was somewhere in 85.
        • McGyver
          • 4636
          Thx. That helps.
          The e24 was kind of like a re-bodied e28, so you can add that car into your list of interchangeability.
          • cory58
            • 1021
            Originally posted by McGyver
            The e24 was kind of like a re-bodied e28.
            Partially correct - early E24s were based on the E12.
            1992 325i Cabrio
            1988 320i Touring
            2000 M5
            1977 530i
            2015 328i - Euro Delivery/Performance Center Delivery
            BMWCCA
            E30CCA
            • reelizmpro
              • 9559
              Post detailed pics of the wheel in question, front and back.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
