speedo intermittently stops
  • digger
    • Nov 2005
    • 6126
    The speedo intermittently stops working (all else on cluster works as it should).
    The speedo doesn't jitter, bounce at all, it either works or it doesn't.
    When it is working while driving and then dies the needle slowly falls to zero
    When it is NOT working while driving and then comes good the needle slowly rises to show the speed
    Does the lack of any sporadic or jittering needle behavior narrow down the focus?
  • ehrawn
    • Aug 2023
    • 205
    I had the same problem. Researching the forum, it seemed like it could be a problem with the cluster: SI board, battery, loose solder connections, etc. I started with the pickup in the differential (62168355008) because it was easiest to tackle. It mostly fixed the problem. Next set will be a complete cluster rebuild from one of the recommended vendors to have all of the connection points resoldered.
    • reelizmpro
      • 9535
      I had a speedo that did that once. I believe it was due to cracked solder joints. I would reflow the solder joints in the cluster, focusing on the main joints and joints that feed the speedo as well as the speedo itself. I would also inspect the SI board while there. Perhaps even replace it if you have a spare on hand. Make sure to use the right screws (short silver) to secure the center of the cluster surround to prevent damage to the SI board.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Northern
        I like cupcakes & sh!tboxes
        • 5234
        Both E30s I owned that were truly drivable had the wires snap at the diff connector. Some combo of strain and corrosion where the wire entered the moulded pin.
        Speed signal would work 90% of the time, but drop to zero occasionally, for random amounts of time.
        When it dropped out or came back, it would snap to the new position quickly, so maybe not the same as your issue but worth checking.
        I ended up taking two pigtails from the same style connector off an e36 parts car and replacing the whole wire until I found clean copper under the back seat inside the cabin...
        Originally posted by priapism
        Originally posted by shameson
        • digger
          • Nov 2005
          • 6126
          i have a new pigtail to fix the diff plug because last time i was there the connector was crumbly and was my first thoughts as to the issue but ultimately i will address the cluster as i need to remove for another reason anyway
          • zaq123
            • Jul 2016
            • 1514
            definitely diff sensor/connector if your odometer stopes spinning as well when speedo dies. While we talking speedo, how innacurate your speedometer is? mine is like 10% under, no sure if it's e30 thing, just started driving this car after long ass complete restoration
            • digger
              • Nov 2005
              • 6126
              Yes, good point, i am fairly certain the odo stops to.
              i am running slightly larger wheel/tyre combo so it is pretty much spot on at 110km/h but it is like 3-5% out at slower speeds e.g. 60km/h. with the correct wheel and tyres yes actual speed is probably 10% lower that speedo at some speeds
              • Vincenze
                • Apr 2019
                • 1018
                You can verify a speedometer by connecting it to +12V and Ground.
                The speed input must be connected to Ground intermittently; the higher the frequency, the higher the speed.
                A p-mosfet can be used controlled by an impulse generator like an Arduino or an oscilloscope.
                Here is a cheap p-mosfet board: https://www.dfrobot.com/product-1567.html
                The schematics is here: https://dfimg.dfrobot.com/wiki/17549...atics_V1.0.pdf
