Steering wheel won’t unlock
  • Imsuperawesome
    • May 2026
    • 2
    My steering wheel will NOT unlock. No amount of jiggling helps.
    tried two different keys. Lubed the lock. Tapped with a mallet. Nothing.
    has anyone experienced this before? What are my options???
    thank you!
  • reelizmpro
    • 9556
    Never experienced this before. Did this just start happening out of the blue? Maybe the ignition switch is worn and no longer unlocking the wheel. People have manually unlocked the wheel by pushing the pin down but this often times damages the steering wheel. I've seen this with junkyard cars without keys. You might be able to get to it by drilling a hole in the upper column cover but I don't have any details. Check YouTube.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Sea Aych
      • Apr 2013
      • 766
      Won't unlock as in you can't turn the key at all? Or turning it doesn't unlock the steering wheel?
      1988 Atlantisblau Euro/Japanese 325i Cabrio
      1989 Schwartz 325i - now M50 powered! - now very dead
      1998 Toyota 4Runner Limited - gone
      My 17,000km Big NA National Parks trip!
      • uturn
        • Dec 2010
        • 1006
        This has happened to me. Jiggle the steering wheel a little harder as you jiggle the key. Then once you get the key to turn, look into pulling the lock core and removing the steering wheel to find out what is actually binding.
        Maybe lube up the plunger that locks the steering wheel or file it smooth if there's any odd nicks.
        • Imsuperawesome
          • May 2026
          • 2
          It just happened out of nowhere. Never had this issue before in decades I’ve owned these cars.
          I have jiggled and lubed more than I would have liked.
          The wheel won’t turn. The lock won’t turn. I’ve tried taking the steering wheel off as much as possible but obviously can’t get it off without unlocking it.
          • 82eye
            • Jan 2009
            • 2101
            2 things you can try
            - have someone rock the car a little back and forth while you jiggle the wheel and try the key.
            - jack the front wheels off the ground to take a little pressure off.
            if you get it to move you may have to replace the ignition cylinder lock barrel which is fairly easy.
            if that doesn't fix it or the lock won't give, you may need to replace the entire steering lock and ign cyl, which is doable but a pain. you don't need a key for the process, it will be replaced anyway. the steering wheel, and column shrouds come off, and everything around the column gets removed to get at the steering and ign lock. there are vids etc online, and there may be a write up here.
