Driving w/o Instrument Cluster - Alternator Charging
  • 82eye
    • Jan 2009
    • 2106
    The resistor is on the instrument cluster PCB.
    answers the reason why the car won't charge without a cluster.
    edit: also points to the fix and where it goes.
    • Vincenze
      • Apr 2019
      • 1039
      I measured the resistor.
      It's 150 Ω (Ohm).
      It's 1 or 2 Watt.
      It probably opens a transistor, so the exact value isn't important.
      • digger
        • Nov 2005
        • 6197
        It's 150 Ω (Ohm).
        It's 1 or 2 Watt.
        Thanks, i will go to my local electronic store
        • digger
          • Nov 2005
          • 6197
          In case anyone is interested this worked fine and you can see the pins 14 the bottom right as you look and 16 positioned 2 above it. you would want to secure it a bit better for longer term though to stop it falling out or anything touching the wires the photo is just temporary for illustration
