Reset Oil Light: Lost Speedo, Odo, MPG Meter
  • Vivek
    attention whore/retard/bitch
    • 6167
    I guess tomorrow I'll try disconnecting the battery for 15 minutes and see if that does anything (might as well), if not, I'll take out the cluster and see what's up.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • dnguyen1963
      • Nov 2011
      • 2651
      Take the cluster out...only a fifteen minutes job.
      • Vivek
        • 6167
        Okay more stuff. Now the car overheats if you go too slow. The clutch fan seems to be okay, but the fan in front of the radiator didn't seem to be spinning. Is it supposed to always spin?
        If you go pretty fast (since the speedo doesn't work, i'm just guessing) around 80 or above, its perfectly fine, below half. It'll shoot up to red in a minute of going slow. It seems to have gotten worse and may or may not be connected to the other issues.
        Any help anyone?
        • dnguyen1963
          • Nov 2011
          • 2651
          How old is your radiator? The heat exchange between your radiator and the air is not sufficient...possible clogged radiator if your fan clutch is working ok. Your water pump might be going too.
          • JoeBaker75
            • Apr 2012
            • 1
            So I did the oil reset light procedure described here, as well as numerous other places, by sticking a paperclip in ports 7&19 and turning the key to position two. The oil light immediately went off, but I waited for over half a minute and the inspection light didn't turn off, so I just took out the key, put the port thing back on, and left it.
            Fast forward two hours. I'm driving the car and notice that the speedo is at zero. Subsequently, the odometer doesn't turn, and the MPG meter under the tach is at 0 when pressing the gas, and goes to 40 when you let off. What the hell happened? I'm as sure as I can be that I used the right ports, and I've never heard of anyone having this issue before. Any help?
            A friend of mine with his m10 model had a similar issue (no mpg, tack) but his speedo "worked" just 30mph off. replace the si and all worked fine again
            Dublin Escorts
            • Vivek
              • 6167
              Thanks...i've been busy with other stuff, but how hard is an SI board replacement? It's not the whole cluster, right (i'd like to keep the orig miles)?
              • dnguyen1963
                • Nov 2011
                • 2651
                Very easy...after you pulled the cluster, there is a single screw to remove and you can pull the whole SI board out. Here is the link...
                • Vivek
                  • 6167
                  Unfortunately.... (above link)
                  This page is no longer available
                  Please note: You might not have permission to view this directory or page using the credentials you supplied.
                  Attention: HyperMart Free Hosting Customers
                  On March 1st, 2004, HyperMart discontinued free Web hosting plans. If you had a free hosting account and did not upgrade, your account has been taken offline.
                  To upgrade to a paid account and retrieve your account and associated Web files, please visit:
                  http://www.hypermart.com/hypermart/upgrade_plans2.bml
                  HTTP 403 - File not found
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    That's strange! I just clicked on the link and it took me to the page without any problem. I do not have an account with them either. If you continue to have problem then go to Google and search "E30 SI Board replacement". The first item should be the one...or try www.beckerelectronics.com
                    • Kershaw
                      • 11822
                      works for me.
                      anyone know what model # the batteries are?
                      AWD > RWD
                        • 34844
                        it depends on which version of the SI board you have, some are nicad, others are lithium.
                        • dnguyen1963
                          • Nov 2011
                          • 2651
                          The later boards (post 1990 I believe) use lithium batteries. They are much shorter than the regular AA that you see in stores. All replacement boards use lithium batteries. These boards disable the charging circuit so no worry about batteries blowing up on you.
