Jacking up e30
  • Nick_e30
    • Mar 2016
    • 173
    Jacking up e30
    Is this where I should be jacking the car up from ? This is my first time I don't know where to do it from . I've seen the pic of the upsidedown e30 but I'm still not completely sure
  • Danny
    • 14216
    No.
    • agent
      Vice Grand Pubaa
      • 7960
      Not unless you want less leg room.
      Originally posted by kronus
      • rturbo 930
        • Dec 2005
        • 2627
        How hard is it to google "E30 jacking points"?
        • stonea
          • 2892
          My Garage
          Feedback
          Instagram: Stone.Hopkins
          • Sputnik
            • Jan 2010
            • 808
            Frame Rails or Pinch welds. Pick your poison.
            • TobyB
              • 5296
              Nowhere. The damned things are too soft.
              I welded 1" square tube under my pinch welds, and now I'm feeling quite stout...
              t
              • Cephas
                • Apr 2012
                • 878
                Ive always just use the frame rails and the points at the rear where the bushings go. Will use the diff if the front tires are really well secured.
                • Kershaw
                  • 11822
                  t
                  That's a pretty good idea for a RWD e30. Front subframe is ideal for an IX.
                  AWD > RWD
                  • DirtyTh3rty
                    • May 2015
                    • 101
                    Frame rails
                    word of advice since this will be your first time jacking this car use some rubber or some newspaper or something in between the jack and the frame rails because like someone said it is pretty soft and over time your jack will eat up all the protective paint and possibly start denting the surface. for the rear i do it from the diff and put stands on the subframe every time so what works perfect.
                    88' BMW 325is - Daily
                    • jdt10768
                      • Feb 2013
                      • 484
                      I use a piece of plywood or a piece of rubber tire between the jack and car frame rail or jack-point to avoid scratching up paint / forking up the jacking mount surface
                      *** and jack stands
                      • Kershaw
                        • 11822
                        Originally posted by DirtyTh3rty
                        Frame rails
                        If you jack from uncoated spots like the control arm lollipop, you won't have this issue. Frame rails and pinch welds should be jack stand only.
                        AWD > RWD
                        • e30_world
                          • Aug 2014
                          • 586
                          Hahaha
                          But really, a simple google search would have gotten faster results. This thread is stupid but funny.
                          F80 M3 Alpine
                          E10 Fjord Blue 2002
                          E28 Blackish 535i
                          E21 Silver 320i
                          Disco1 98 4.6
                          E30 Cirrus coupe S50 SOLD
                          E30 325i SOLD
                          E30 Alpine 325i vert Euro spec SOLD
                          E30 Alpine coupe 325is SOLD
                          • george graves
                            • 20003
                            Originally posted by Matt-B
                            • TobyB
                              • 5296
                              Gaaa!
                              t
