New wheel bearing question
  • Alaska Ted
    • Apr 2015
    • 145
    Just bought a new FAG rear wheel bearing. The inner race is split and both sides seem to move laterally quite a bit. Is this normal? Did I get a bad bearing?
    Thanks,
    Ted
  • reelizmpro
    • 9552
    pics?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • TobyB
      • 5280
      I never noticed new ones doing that. But they do sometimes wiggle around just a little
      as you're assembling them, so that might not be unusual...
      t
      • Kershaw
        • 11822
        This is normal. It'll cinch down once you install it.
        AWD > RWD
        • Alaska Ted
          • Apr 2015
          • 145
          Thanks guys. Just didn't seem right to me. I got impatient and took it to a local import shop where I've had work done in the past. They said it was fine. Got back on here and read the same. The pisser is I had pressed it in before I noticed the lateral movement. So then I get bent out of shape and pull it back out. All for nothing. Live and learn.
          Ted
          • Kershaw
            • 11822
            The doubt will be even worse when you do the front wheel bearings on your ix. I got everything assembled, ready to install, and the hub still had a little play before I torqued the hub nut to astightasicouldgetitwitha6footbreaker.
            AWD > RWD
            • mr.
              • Jun 2013
              • 513
              My new rear bearings were the same as well. It threw me off a bit, but I threw them in anyway. All seems to be going well. There is some noise out back though. No trunk tar, spare wheel or trunk lining will do that I guess. Dunlop Direzzas probably don't help either.
              Sent from my SM-G530T1 using Tapatalk
              • Alaska Ted
                • Apr 2015
                • 145
                Its in tight and smooth like butta. Gotta say I had some serious doubts. Like kershaw said, it still had a bit of wiggle until I cranked down the hub nut.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Nothing like 200lbs of torque to make a bearing purrrr :)
                  Good job
                  Alice the Time Capsule
