Cheap fuel pump?
  • OriginalSterm
    • 34
    Cheap fuel pump?
    Had anybody tried these pumps yet? Seem awfully cheap compared to all the other sources out there. I was thinking about trying this in my late style tank as a transfer pump to prevent starvation during long sweepers.
    • 34839
    you get what you pay for.. that is almost certainly some poorly made chinese knockoff.
    • McGyver
      • 4553
      I've used TRE fuel pumps in several cars, never had a problem. Currently they're $70:
      TREperformance sells high pressure 255 LPH fuel pumps for all BMW vehicles including the 325, 535, 740, M-Series. These performance pumps will fit any BMW and flow 255LPH and support 500hp.
      • Adrian_Visser
        • Jun 2006
        • 2823
        Just get a Walbro 255. Here's the DIY on how to install it:
        '89 Alpine S52 with goodies
        • ForcedFirebird
          • Feb 2007
          • 8300
          Originally posted by OriginalSterm
          https://www.ebay.com/itm/Fuel-Pump-G...4383.l4275.c10
          We added surge tanks in our enduro cars after battling with the duel pumps and them failing. Fuel pumps don't exactly like to run just wide open to an empty hose (high pressure pumps are worse).
          https://www.r3vlimited.com/board/sho...d.php?t=134915
          Walbro brand is copied so much, hard to get a good one anymore. I have switched to Aeromotive as they make a 340gph that fits just as nicely and is only ~$125.
          The pump the OP is talking about is a low pressure lifter pump that came in the m3, 325e and early 318 (note the 12mm supply hose, and return at the pump carrier, late models have the return down low on the passenger side saddle of the tank). When using a dual pump setup, it's best to use a low pressure, high volume pump, or they burn up pretty quickly when they are just running to the other side of the tank (even the low pressure pumps don't seem to last).
          Also, to add a second in-tank pump you would need the entire carrier to replace the level sender on the driver side.
          So, for the price, it is worth getting that setup just to get the carrier that cheap - always can put a quality pump in it's place.
          john@m20guru.com
          Links:
          • Adrian_Visser
            • Jun 2006
            • 2823
            Interesting, that's good to know. I see I skimmed the OP pretty bad didn't I?
            • reelizmpro
              • 9493
              Did you guys notice how that carrier mounts to the tank??? LOL HMMMMM that's gonna be a big HELL NO for me.
              Find a clean OEM carrier and install a TRE/Walbro, etc and do it right the first time.
              88 M3 - LACHSSILBER/SCHWARZE
                • 34839
                I was wondering about that. I'm not super familiar with the early two-pump setup so I wasn't sure if that's what it was supposed to look like. Yeah, you're going to have to drill holes into the tank to bolt it in. Nope nope nope...
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  I overlooked that part. :/
                  Yeah, no.
                  john@m20guru.com
                  Links:
                  • djjerme
                    • 5082
                    What's the Aeromotive pump you're using? I may upgrade the racecar setup this year.
                    2016 Ford Flex
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      One like this - not sure which way was the offset (they have same/opposite of supply), not at the shop to look at one. :/
                      P/N 11541: 340 Fuel Pump, Offset Inlet**Offset Inlet** The Aeromotive 340 Stealth Fuel Pump is a high-output, in-tank, electric fuel pump that fits most popular EFI applications. The Aeromotive 340 is a compact, lightweight pump that bolts into many existing hanger assemblies. (to find your vehicle, see the application
                      EDIT: I typed "gph" earlier and it's "lph"...
                      john@m20guru.com
                      Links:
                        • 34839
                        Yeah, no.
                        like, how do you even tighten that down? 100000x, NO.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          After my reply, I was back to working and thought about that. No way to get inside the tank to tighten the nuts/bolts.
                          john@m20guru.com
                          Links:
                          • Sonny
                            • Feb 2019
                            • 100
                            Cheap fuel pump?
                            Don’t be an idiot, you have 12V current powerful enough to weld metal, and your going to stick it in your fuel tank? And it’s made in China????
                            Suspension, brakes, tires and Anything that is not cosmetic and is linked to your safety, do not buy replica Chinese crap man, your life depends on it.
                            I would buy window tint made in China and some detailing towels, but tell me to order brake pads/rotors or wheel bearings or control arms, no way. Now imagine a fuel pump.
                            • TobyB
                              • 5213
                              Pleasantly, you don't have enough oxygen in the fuel tank to start a fire.
                              As long as you've got the stock evap system, that is.
                              t
                              underwater welder
