light weight flywheel
  • e30 gangsta
    • 3877
    #46
    k thanks for the help...
    • e30 gangsta
      • 3877
      #47
      how about clutch kicks???? like dumping the clutch will it make the flywheel fail faster becuase its lighter???
      • Digitalwave
        is a poseur
        • 6299
        #48
        I don't think flywheels really fail, but clutch kicks will make the clutch not last as long.
        RISING EDGE
        • EverWiser
          • Aug 2004
          • 313
          #49
          The flywheel, because of its weight, acts as a damper. It smooths things out when accelerating and due to its spinning weight smooths your deceleration. Equate a lightened flywheel to how a motorcycle behaves: when you get on the gas you GO right then; when you let off you slow down right then. Lighten the flywheel in your car and you accomplish the same thing. Only thing I would see as detrimental is that steady state cruising will not feel as smooth (so if you spend lots of time in your car for longer trips the jerkyness might get old) and the drivetrain will be "shocked" more often due to the lower dampening effect of the lightened flywheel so there may be some long-term reliability issues with "stock" components. Just my .02...
          • Digitalwave
            is a poseur
            • 6299
            #50
            Originally posted by EverWiser
            steady state cruising will not feel as smooth (so if you spend lots of time in your car for longer trips the jerkyness might get old) ...
            I've actually noticed that in my car, its not bad and/or bothersome to me though.
            RISING EDGE
            • e30 gangsta
              • 3877
              #51
              k thanks... and of course it kills the clutch....
              • e30 gangsta
                • 3877
                #52
                im such a noob...
                • Sean
                  • 5793
                  #53
                  I was under the assumption that my 1988 325, Super Eta, manufactured in early 87 I believe, had a dual mass flywheel.
                  I got a clutch for this, so hopefully that's correct.
                  I read that you can switch to a single mass flywheel? What does this involve? I could easily get ahold of a 325i flywheel - but if I did this, I'd need a different clutch too, wouldn't I? What else would I need to change?
                  Thanks! ;)
                  - Sean Hayes
                  • Digitalwave
                    is a poseur
                    • 6299
                    #54
                    Thanks! ;)
                    You can use the single mass if you get a clutch and throw out bearing for the single mass.
                    RISING EDGE
                    • 88325isboy
                      • Mar 2004
                      • 1058
                      #55
                      about how did it cost you guys the machine shop down the street from me said he would do it but he didnt know a price to charge me. what side of the flywheel do thet shave off?
                      -Bobby
                      '87 325 (Track Rat)
                      '04 C5500 Wrecker (Work)
                      '94 525i (Daily)
                      '90 325i (R.I.P)
                      H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
                      • BS87
                        • 1606
                        #56
                        If the guy doesn't know how to resurface and lighten a flywheel, i personally would not take it to him. I dont like taking chances with driveline components.
                        • 88325isboy
                          • Mar 2004
                          • 1058
                          #57
                          ya true that but i was going to get one from the junkyard and let him try to do it. but i might just send it to Jim Rowe. he said he would give me a good deal on it.
                          -Bobby
                          '87 325 (Track Rat)
                          '94 525i (Daily)
                          '90 325i (R.I.P)
                          • e30vert
                            • Jan 2005
                            • 1789
                            #58
                            I once caught an 8 pound trout. :)
                            • Joey
                              • Oct 2004
                              • 35
                              #59
                              ..That's nice.
                              Does nothing need to be adjested for clearance or anything when retrofitting a single-mass flywheel and matching clutch assembly to an early Eta?
                              • cthulu703
                                • Oct 2004
                                • 288
                                #60
                                Originally posted by Stu Mc
                                The chatter is common for LTW flywheels, I'm not exactly sure what causes it, but every car I've ridden in with one chatters when the clutch is disengaged. It's raw as hell. :twisted:
                                Is it possible that the crank/flywheel assembly is balanced from the factory and when the flywheel is lightened the system becomes unbalanced? Do you notice resonances in the gearbox sound with the lighter flywheel? At first impression, I would think that the extra gearbox sound is probably from radial loading of the input shaft of the transmission. Either due to an uncentered, balance flywheel or a properly installed unbalanced one. To the people who had their stock, single mass flywheels lightened: did you have them dynamically balanced afterward? I personally, would not put a lightened flywheel on my car that had not been balanced, as it will hurt your motor, especially at higher RPM's.
