light weight flywheel
  • trent
    Originally posted by Jordan
    Originally posted by Stu Mc
    mines 7 and a half.
    Originally posted by grapedrink
    Mine is 8.5lbs
    Aluminum flywheels don't count.
    Yes they do. Much better than a lightened stocker. 8)
    • fletcher miller
      • Sep 2004
      • 78
      i think when i get the money i might just go with a new flywhl and cluch mybe get an 8.5 pounder that will probably make a huge differance in the 0-60 :twisted:
      • SlammedE30
        • 741
        Mine's an 11lb steel one :P
        :roll: :roll: :roll:
        • Digitalwave
          is a poseur
          • 6284
          Originally posted by Mike 91 318ic
          how does this affect the idle? metic mechanic has a lightend dual mass flywheel I was considering... has anyone tried it?
          M
          Originally posted by aaron_silva
          What kind of car do you drive? If it is an M42, you can swap the M20 single mass flywheel (shaved) and a few other parts and you can lose a lot of weight.
          Aaron
          My idle is 100% normal. The only thing is that it sounds like there is marbles in the gearbox when idling with the clutch out. I guess its very common on Getrag 260's with lightened flywheels.
          RISING EDGE
          • bimmer8604
            • 3017
            mines 11.5, (oem flywheel lightened). I only noticed good things about the flywheel, better accel, and def. better pick up coming out of turns.
            Hi grant.
            Kyle
            1988 M3, 97 840, 99 XJ
            DILLIGAF
            • The Sly
              • 31
              I just did a fresh engine swap to my Convetible which had lots of miles to it...
              i have got a light single mass flywheel in there with a 6 puck racing clutch with new release bearing, and after i started the engine i could hear the same as you are describing..????
              Got to my local BMW Tech and he said it was normal cause the tranny has lots of miles and it will make that noise...
              he also said that back in the old days before the dual mass flywheel this would happen often...
              Nice to know that i am not the only one :D
              • Stu Mc
                • 4083
                The chatter is common for LTW flywheels, I'm not exactly sure what causes it, but every car I've ridden in with one chatters when the clutch is disengaged. It's raw as hell. :twisted:
                • Digitalwave
                  is a poseur
                  • 6284
                  Yeah, my friends notice it at stop lights. Even ones that know nothing about cars say "cool" when I say its because of the ltw fly.
                  RISING EDGE
                  • Stu Mc
                    • 4083
                    It's most noticeable pulling through drive-thru's (bank, wendys), you can really hear it up against the wall. :D I let a friend drive mine once, he started it up, let the clutch out (neutral), and was like, "WTF is that!" :P
                    • Digitalwave
                      is a poseur
                      • 6284
                      Yep, thats when my friends noticed it last time. My ticking injectors don't help either :)
                      RISING EDGE
                      • kylebes1
                        • May 2004
                        • 2804
                        i have a 13.5 lb almost light wieght flywheel.
                        how does a 7.5 flywheel compare? make much drivabillity difference?
                        • Stu Mc
                          • 4083
                          It's advertised as 8.5, but was 7.5 on my scale. :) As you know, the more weight you take out of the flywheel, the less vibration resistence and dampening you have going through the driveline. That said, the throttle is extremely sensative on my car, and took a good bit of driving to get completely used to (after coming from a 28 pounder) :D
                          • kylebes1
                            • May 2004
                            • 2804
                            if that is the only "problem" you have to live with you have a tough life. :D
                            If I get the opportunity to change i will sell my 13.5 and go with the 7.5 or maybe the 5.5 i saw recently.
                            • M-technik-3
                              • 18946
                              Originally posted by fletcher miller
                              My fly wheel is 28 lbs and it really bugs me its sucking my power :evil:
                              It's not sucking your power... It just has more rotational mass that's spinng to retain interia. Granted it does not spin up as faster but it's not parasitcally eating your HP.
                              • kylebes1
                                • May 2004
                                • 2804
                                yeah it is just the fact that your engine has to get the higher inertia of the 28lb flywheel moving as well as move your car, initally. with a lighter one the engine is doing more moving of the car.
