The 5 Year Restoration - E30 M3 Reborn
  • punnzzells
    • Aug 2005
    • 335
    #196
    Wow.... that's a BIG project.... sunroof alone is enough to drive you nuts!
    Great pics.... keep'er coming. :)
    • CurrusDei
      • Mar 2014
      • 673
      #197
      New M3 Owner... The Build Thread
      Thought you guys might like to see this pic. We just had our second child, first boy, and when my wife wanted to have his newborn photos taken I had only one request...
      _______________________________________________
      5 Year M3 Build, In Progress
      RMT200 Retrofit
      • bradnic
        • Jul 2012
        • 3554
        #198
        Born in greatness... Congrats!
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • 613EDRTY
          • Apr 2014
          • 267
          #199
          easily the best baby picture ive seen congrats on #2
          Rescued 1986 325e Coupe
          1988 325ix Touring 5spd currently being rescued
          Ottawa, Ontario, Canada :finger:
          • CurrusDei
            • Mar 2014
            • 673
            #200
            thanks! He's getting an early start.
            RMT200 Retrofit
            • ChaosTheory
              • 517
              #201
              That's awesome me and my wife both agree.
              • Nats88M3
                • Sep 2013
                • 209
                #202
                Congratulations! That will be me in 3 months but with a baby girl.
                • CurrusDei
                  • Mar 2014
                  • 673
                  #203
                  Field trip to Markert Motor Works for an engine inspection before I pull it for paint. Curious to see what they'll find
                  At the shop
                  RMT200 Retrofit
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    #204
                    Waiting for some good updates :)
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • 2mAn
                      Señior Mod
                      • 21079
                      #205
                      Dont let them convince you to go OBD2
                      Very cool attention to detail here.
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • CurrusDei
                        • Mar 2014
                        • 673
                        #206
                        So I'm a bit behind on updates. Here's the latest. Removing the sunroof motor is easy.
                        Just note which wires go where on the relay
                        Here's another thing that wasn't helping my sunroof-c clip had come off somehow.
                        After the motor is out you can clearly see how it works. The cables are threaded and the gears run through the threads, pushing the cables through the copper colored tubing to close the sunroof, or pulling the cables to open it.
                        Cables are easily removed once the motor is out by pulling from the side that attaches to the sunroof
                        The tubing comes off easily with a few bolts in the center (shown above) and on the ends
                        So that's the sunroof done for now. I don't want to remove the rest of the track and the silver/chrome strips because they are glued down, and in the case of the track, is glued down in a very difficult to reach place. This will be easy for the body shop to tape off so they don't get overspray.
                        Now removing some bits from the interior
                        Steering column cover comes off very easily with a few screws on the top and bottom.
                        And removing some wires and modules under the driver's seat. This is the cruise control module according to real OEM, which is confusing because I thought I already removed the cruise control computer. Maybe just 80s technology
                        This is how the wires go in. More a reminder for myself than anything
                        Hood latch out
                        Much more to do on the inside wiring. I think I'm going to pull all the wiring from the engine bay but try to leave the cabin wiring intact. We'll see.
                        Speaking of engine bay...
                        Removing relays
                        Removing coolant sensor wire
                        Removing ignition coil
                        This 02 sensor wire travels quite the path from the ECU, through the firewall, under the coolant tank, down the engine bay, across the firewall above the transmission, and down onto the exhaust manifold
                        I disconnected it but left the sensor in the manifold for now
                        GOODBYE UGLY PLUG WIRES! Replacing these with red ones.
                        Coolant temp sensors coming off
                        The little rubber loom piece was tricky to get off. Oil leaks had gunked it up pretty badly
                        Very sophisticated German cowl drain system
                        Hood latch release off
                        Throttle cables off
                        Very sophisticated coolant overflow drain
                        And air box off
                        RMT200 Retrofit
                        • bradnic
                          • Jul 2012
                          • 3554
                          #207
                          I think you meant sunroof motor in the first pic right?
                          The "cruise control module" behind the driver dash is actually the OBC control unit.
                          You are SOOO the right guy to own this car. Absolutely adore this thread man. Thanks for posting!!
                          HOWTOs:
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • CurrusDei
                            • Mar 2014
                            • 673
                            #208
                            Yes, sunroof motor. Fixed it. And thanks for the info on the mystery black box :up:
                            RMT200 Retrofit
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #209
                              Beautiful!
                              Check Us out on Facebook
                              Full Product Line Tuning
                              • IceWhite
                                • Jan 2015
                                • 945
                                #210
                                Just saw this thread today. Man, Awesome thread and attention to detail on the car. Hope you enjoy it for years to come.
                                Congrats on your new born. Love that pic of him in the engine bay.
                                1990 325i
                                2004 330i Individual 6-speed
