The 5 Year Restoration - E30 M3 Reborn
  • bradnic
    • Jul 2012
    • 3554
    #526
    The missing link!!! The tips of my throttle and cruise cables look so sad.
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • CurrusDei
      • Mar 2014
      • 673
      #527
      If you order from BMW the new ones come in black.
      If you go this route, wear gloves. This stuff burns worse than the acid I'm using. I cant believe people put this in on their head. I checked this morning (without gloves) and the tips of my fingers were white from the peroxide
      The pieces were whiter, but still yellow. Reset it and am letting it sit all day. Some of the electronics videos I saw took multiple days for solid results.
      My work bench for plating already looks like a meth lab. Now it looks like I'm growing weed in my garage closet. Pair that with both my E30 and E90 having LSDs and you've got quite the party going on in the garage.
      _______________________________________________
      5 Year M3 Build, In Progress
      RMT200 Retrofit
      • CurrusDei
        • Mar 2014
        • 673
        #528
        Well, it works. Very slowly, but it does work. This is after 3 days...
        RMT200 Retrofit
        • Roadrunner
          • Mar 2016
          • 221
          #529
          Originally posted by CurrusDei
          Google search, and....
          New sticker is in process!
          Burning the midnight oil (and your phone's battery) to research a fuse box label... that is some serious dedication to the project!
          Absolutely incredible work! :up:
          1994 E30 316i Design Edition Touring / 1991 E30 318is / 1992 E34 M5
          Instagram: @ro4d_runn3r
          • CurrusDei
            • Mar 2014
            • 673
            #530
            2.5 Years In... M3 Build Thread...PAINT COMPLETE!
            Ha, thanks! A lot of this work happens at night - good way to wind down.
            Tonight's unwinding - driver door handle installed...
            Reminder pic from the disassembly, How all this goes back together...
            Shiny shiny
            Going back in!
            RMT200 Retrofit
            • CurrusDei
              • Mar 2014
              • 673
              #531
              Final result from my hydrogen peroxide experiment...
              I switched over from ziplock bags to plastic wrap. That let me lay down the wrap first, then place the parts and apply the hydrogen peroxide cream more precisely than the bag did. Then I put another layer of plastic wrap on overtop to keep it from drying out. After 73 more hours...
              Very satisfied! It may take a long time, but it works.
              In other news, I have finally finished plating all my boxes of hardware. I'll have some stragglers I find as I go through I'm sure (like the rear fuel pump components), but all the heavy lifting is done. I took step by step pics of my last run, will post instructions and observations separately soon - I got a LOT better at this as I went on.
              Results of last major run:
              RMT200 Retrofit
              • bradnic
                • Jul 2012
                • 3554
                #532
                Yes!
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • CurrusDei
                  • Mar 2014
                  • 673
                  #533
                  Yes!
                  buying some hair product soon?
                  RMT200 Retrofit
                  • bradnic
                    • Jul 2012
                    • 3554
                    #534
                    absolutely. side by side on your pics - a little after/before motivation for all of us..
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • CurrusDei
                      • Mar 2014
                      • 673
                      #535
                      Quick litigious society disclaimer (not targeting you Brad, this is just for the general record). I mean it when I said this stuff burns skin - this is just a record of what I did, so if anyone uses it as a guide, do so at your own risk. Also, it looks like the chemical process works by removing Bromine, a fire retardant initially baked into the plastic, and which oxidizes into a brown color. So the plastic pieces may not be as flame retardant after this process, so again, proceed at your own risk.
                      Here's an article that touches on the chemistry.
                      RMT200 Retrofit
                      • bradnic
                        • Jul 2012
                        • 3554
                        #536
                        Wise. very wise.
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • CurrusDei
                          • Mar 2014
                          • 673
                          #537
                          Tool kit in!
                          Careful cleaning before mounting.
                          Haven't installed the sound deadening yet because it's tan. Need to find grey, like the original one that came on the car. Put it in there loose for now..
                          And roadside assist label
                          RMT200 Retrofit
                          • bradnic
                            • Jul 2012
                            • 3554
                            #538
                            :popcorn:
                            sticker envy. bad.
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • CurrusDei
                              • Mar 2014
                              • 673
                              #539
                              Door work!
                              Some rubber bits that keep the metal mechanisms from contacting each other or the painted interior of the door...
                              These little guys had to come from Germany and were $6 each. They're the size of a pencil eraser.
                              Replaced these spacers as well.
                              New weather stripping (installed the rear lower tracks as well, not pictured)
                              Window gears back in place. This thing is like a contortionist. It can get into so many positions it took a minute to figure out the right one again.
                              Passenger door also has its handle on now and both door strikers are well aligned so they open smoothly.
                              Fuel tank access covers back on. Large one got a new gasket as it was only in good shape. Small one gasket was in great shape, put back.
                              RMT200 Retrofit
                              • ClassicE30
                                • Feb 2013
                                • 130
                                #540
                                Do you have a PN for the roadside assistance sticker or could you pint me in the direction where you forbid it? Thanks in advance! And biblical build BTW!
