The 5 lug swap truth thread!!!!!!!!!!
  • Caperix
    • Feb 2018
    • 195
    #181
    Originally posted by jbontke
    Why not the sleeve on the spindle?
    I'm currently looking at brake/wheel upgrades for my 91 325. My main issue on the sleeves is that they do not work with abs without repositioning the sensor ring. The redrilled hubs do look a little thin in some spots. If the hub could be pressed out of the bearing without damaging it & a new 5 lug hub pressed in that may be the best option, but as e36 use a different bearing size one would have to be custom built.
    There are options for 4 lug bbk but they all use an aftermarket caliper, 5 lug swaps can use factory parts. Wheels are about the same price but 5x120 has more options. I'm sure hose, pads & rotors would improve the braking, but factory e30 parts will look tiny on lager wheels & may not be up to added power in the future. Tire choices are getting limited on anything below 17" so a wheel upgrade from the 14" is needed.
    Does anyone know the difference on z4m front knuckles? They have e36 strut mounting but have different part numbers from early & late e36m knuckles?
    • moatilliatta
      • 6152
      #182
      Z4M knuckles also use std E46 arms vs the bigger ball joint in the M arms. The E36 Strut mount is nice if you already have those..
      @Zakspeed_US
      • Caperix
        • Feb 2018
        • 195
        #183
        Do you know if there is any geometry difference in the z4m vs the e36m knuckles? If feels like the strut towers are further forward on a z4 but that may just be the extra distance to the firewall.
