5-lug Setup
This is a sticky topic.
  • feef
    • Mar 2014
    • 17
    #301
    Hello everyone,
    This is my first post so excuse me if this is in the wrong section.
    As far as hp and torque, what are the limitations of the stock 4-lug setup? At what point with a built motor would I need to do a 5-lug conversion? Thanks in advance.
      • 34839
      #302
      you don't. it's basically done for looks.
      • blusylver
        • Feb 2013
        • 230
        #303
        I did it because I needed wide wheels and thereally isn't much available in 4 lug.
          • 34839
          #304
          that's not really true, but maybe you didn't like the way the ones that are available look. :p
          • bavarianbrawler
            • Feb 2013
            • 33
            #305
            Great thread. Thanks for sharing.
            • _Keith_
              • Jan 2011
              • 128
              #306
              Be nice if one post had all this info. Sounds like this site that's now gone had it.
              87 325i Coupe - Sold
              95 M3 Track rat - Sold
              87 325i Vert - Sold
              87 325is S52 swap - Sold
              99 M3 (Estoril) - Sold
              03 525i Touring - Current
              03 325i Touring (Mtech Conv) - Current
              88 325i Vert - Current
              • jph
                • Feb 2015
                • 463
                #307
                Here is what I plan to do with the info I have gathered over hours of research on this site:
                FRONT:
                '97 E36 M3 spindles, wheel bearings, hubs, calipers, rotors *315x28*, and ABS sensors
                '97 E36 M3 control arms
                '97 IE Delrin offset control arm bushings
                E36 M3 Bilstein sport strut
                E30 325i specific H&R springs
                E30 325i top hats
                REAR:
                E30 325i trailing arms
                E30 325i Bilstein sport shocks
                E30 M3 hubs and wheel bearings
                E46 325i rotors *294x19*
                E39 528i calipers and carrier (with Rongineer's custom brackets if he will do just brackets)
                From my research it seems that this setup will allow me to run a staggered wheel set with E36/E46 front fitment and something like an et20 in the rear. This also provides a big upgrade to braking performance and shouldn't be too far off from a full E36 M3 brake setup with the exception of a slightly smaller rear setup. Also considering swapping the master cylinder to the larger E36 M3 unit to keep up with the new brakes.
                If anyone has any thoughts on the above please post up!
                • _Keith_
                  • Jan 2011
                  • 128
                  #308
                  Well I picked up a 98 ti as a parts car.
                  So I'm planning on the following.
                  Front
                  97 M3 front hubs, struts and control arms with offset lcabs.
                  Rear
                  318ti complete rear assembly and brake system.
                  -will upgrade to something a bit bigger down the road.
                  87 325i Vert - Sold
                  • getouth
                    • Jan 2010
                    • 3343
                    #309
                    This might have been discussed???? Don't crucify me........ What does a complete 5 lug 318ti rear set up go for? It complete brakes rotors calipers....... Everything. Help ASAP! I really don't want to over spend. Pm with answers if possible thanks.
                    FEEDBACK:
                    http://www.r3vlimited.com/board/showthread.php?t=316212
                    BMWCCA #398608
                    IG @yagayo38
                    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                    • clavinZERO
                      Hella sick E30
                      • Mar 2004
                      • 2027
                      #310
                      I got my front e36 m3 and rear 318ti setup for 1200 bucks. Then I opted to do new brakes all around. The meat and potatoes were in good shape but the rear shocks were from my car already and the front struts I wanted match to the rear (existing) Bilsteins. Depends on whwre you buy and what you service/replace on the setup.
                      "BMW Style 32 Poster-Child"
                      HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                      **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                      • roznic
                        • Mar 2013
                        • 2876
                        #311
                        You prob better off telling what are you buying/offered and for how much?!
                        • getouth
                          • Jan 2010
                          • 3343
                          #312
                          Complete rear trailing arm minus shocks 700.00
                          FEEDBACK:
                          BMWCCA #398608
                          IG @yagayo38
                          • e30m3s54turbo
                            • Jun 2010
                            • 3265
                            #313
                            I bought my 318ti trailing arms for $300.
                            • Rouvld
                              • Sep 2014
                              • 569
                              #314
                              Is it possible to buy a oem e30 m3 suspension new.
                              • jph
                                • Feb 2015
                                • 463
                                #315
                                Yes, at least the fronts are available at this time. Not sure about the rears. They are prohibitively expensive though. Only time I can think of using them at their price is for restoring an all original E30 M3.
