5-lug Setup
This is a sticky topic.
yes, you can bolt up all 323ti parts straight to the e30, no issues at all.
I've stared at 318ti and e30 trailing arms for months, I've NEVER noticed a difference, so I don't think there's a toe difference. Maybe you're looking at different ride heights, that gives you that perspective.Comment
any of you have experience with e39 or e46 abs? I'll be trying to use one of those in the future...
as for the trailing arm maybe the back of the car is not as large as the middle and that is why it feels wrong...
Uploaded with ImageShack.usComment
on the front end of a e36 m3 swap, are we able to use m3 sway bar links? u know the ones that bolt on to the strut.Comment
yes you canComment
Trying to decide on 5-lug wheel options. How much more does the hub stick out compared to stock. Most likely going to go with e36m fronts and have not decided on the rears.
sorry if my terminology is off.
WTB
-convertible carpet, no rips, in socal.
-s52, s50, m52, m54
-harness, accessories, transmissionComment
wow so much for really low offset wheels huh? thanks guys!
WTB
-s52, s50, m52, m54
RH 7j 15 inch et13 RH rims 205/55 r15 4x100 is very close to Azev A 16" ET20 7.5j 225/45 16" 5x120
I am in the middle of doing my rear swap. Since I am swapping an 89 model car, I guess I can't just use the 318ti hubs and brakes I have? When I took the hubs off of the 318ti axle and tried to put it on the e30 axle, the splines were not the same. I can not slide it on. So i'm guessing i need to swap the whole trailing arm assembly like it says in Aptyp's writeup. My question is then, if I have to use the 318ti axle with the 318ti hub, will the diff side of the axle bolt to my 3.73 e30 diff flanges?Comment
