Share your 5 lug setup and wheels
This is a sticky topic.
  • craz azn
    • 749
    #61
    Originally posted by bimmer630
    also you are running non-M knuckles, same as me. It seems like the guys with M-knuckles dont have any wheel positioning problems. I read somewhere that the M knuckles may have some additional built in caster, pushing the axle centerline even more foward than the offset CABs and 97 M-arms will give you (this was just an idea, nobody can seem to confirm it)
    Its a myth. M knuckles and non M knuckles are the same (relation of the centerline of the spindle to the centerline of the balljoint)
    The only difference I saw when comparing them side by side was the offset of the brake caliper was completely different.
    Rippin' Proper | Youtube | Vimeo |
    • e30s52
      • Oct 2007
      • 5235
      #62
      Hey dave,
      You used brand new break pads right? because I have a set with about 50% worn off. Do you think they will clear or maybe use some 3mm spacers along with it?
      www.gutenparts.com
      • bimmer630
        • 1230
        #63
        interesting.. and good to finally see that somebody has compared the two.
        i wonder still what it is that causes some guys' swaps to end up with the front wheels off center in the wheelwell, and others end up looking fine
        • daniel
          • 6703
          #64
          my 5-lug setup is updated.
          style 4's, et23 16x8
          http://instagram.com/dslovn.drives
          • clavinZERO
            Hella sick E30
            • Mar 2004
            • 2027
            #65
            -'97 E36 M3 front complete strut/brake assemblies with stock E30 strut mounts on top
            -Z3 1.9L rear complete: trailing arms / hubs / brakes
            -'97 E36 M3 control arms
            -E30 offset control arms bushings, polyurethane
            -Ireland Engineering polyurethane trailing arm / sub-frame bushings
            -Ireland Engineering weld-on toe/camber correction kit
            -E30 fitment H&R Sport springs
            -'97 E36 M3 front Bilstein Sport struts
            -E30 rear Bilstein Sport shocks
            -Eibach swaybars, 22mm front and 19mm rear
            -17" x 7.5" BMW style 32, Radial Spoke wheels, et41
            -215/40/R17 tires
            Notes: Rubbing in front only lock to lock on the inside, on the frame. No rear rubbing with 5 people in car and no catching lip on front fender either.
            PICS:
            </pic whoring>
            "BMW Style 32 Poster-Child"
            HTTP://WWW.CLAVINZERO.COM/e30-5-lug
            **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
            • daniel
              • 6703
              #66
              -215/40/R17 tires
              i think you should get the 8.5's in the back and run 245's ;)
              • Aptyp
                • 6584
                #67
                I have an opportunity to pick up a set of MoMo Mirages with center caps. really debating it right now :( I don't really like the looks, but I could have them powder coated and polish. Should I?
                • clavinZERO
                  Hella sick E30
                  • Mar 2004
                  • 2027
                  #68
                  Originally posted by aptyp
                  i have an opportunity to pick up a set of momo mirages with center caps. Really debating it right now :( i don't really like the looks, but i could have them powder coated and polish. Should i?
                  pics!!??
                  • Aptyp
                    • 6584
                    #69
                    Daniel's old wheels
                    • clavinZERO
                      Hella sick E30
                      • Mar 2004
                      • 2027
                      #70
                      Originally posted by Aptyp
                      Daniel's old wheels
                      **crickets**
                      HINT: clavinzero is outta the loop, needs picz0rz plz!
                      • decay
                        • 5637
                        #71
                        yes.
                        digging the new wheel choice daniel, looks classy.
                        past:
                        1989 325is (learner shitbox)
                        1986 325e (turbo dorito)
                        1991 318ic (5-lug ITB)
                        1985 323i baur
                        current:
                        • Aptyp
                          • 6584
                          #72
                          e36 m3 control arms or e30 m3 parts...
                          • Aptyp
                            • 6584
                            #73
                            **crickets**
                            lol, Clavin, it's the very first pic in this thread
                            • clavinZERO
                              Hella sick E30
                              • Mar 2004
                              • 2027
                              #74
                              <----------------- loser.
                              • Aptyp
                                • 6584
                                #75
                                don't feel bad, this is what I'm rolling on at the moment and I need new wheels
