ABS Retrofit
  • johnaoshea
    • Jul 2017
    • 7
    ABS Retrofit
    Hi everybody ,
    I posted this in the touring specific forums but thought it might get more traction here.
    I have an 89 320i touring that came without abs and was wondering if any of you have ever retrofitted a working system into a late model. Getting the physical parts and running brake lines wouldn't be an issue for me. But I’m concerned about adding in the abs computer module. Thanks guys !
  • cwlo
    • Sep 2015
    • 131
    You can run the mk60 ABS from the e46 M3. The dme is integrated with the unit. It is a big upgrade over stock, but requires some plumbing and wiring. You'll have to decide if its worth the extra work.
    • citizen_insane
      • Jan 2013
      • 216
      This is also what I was going to suggest. It's expensive and complex, but it's supposed to be one of the best standalone ABS modules ever built. A lot of guy put them in race cars even from other makes. You will have to convert to 4 wheel speed sensors to use traction control, which can be a bit of a pain. I plan to do this eventually on my car as a bit of extra insurance on the track.
      • Caperix
        • Feb 2018
        • 195
        I sounds like teves made a race version of the newer mk60e5 dsc, that should be easier to find as all e9x & e8x cars used it. I do not know if there is any hardware differences of all software though.
        • R3Z3N
          • Jan 2011
          • 3056
          Here is the wiring for the MK60 ABS which runs fine standalone. There is one version which the firmware can be modified to your weight, weight bias, tires, etc, only a handful of people can do that. It would be wise to retrofit the Steering sensor and yaw sensor:
          • Victell
            • 1083
            Originally posted by johnaoshea
            Hi everybody ,
            Did you end up doing this?
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              could you reupload this? The attachment seems to have been lost
              Originally posted by priapism
              Originally posted by shameson
              • R3Z3N
                • Jan 2011
                • 3056
                Fixed my post, wiring now directly linked to my host.
                • bmwman91
                  • Oct 2004
                  • 3134
                  Holy shit, this is awesome. Expensive and not exactly "first DIY adventure" status, but pretty damn awesome.
                  What sort of cost is someone looking at, all-in, for the parts and materials (assuming clean eBay parts where appropriate)?
                  Transaction Feedback: LINK
                  • Northern
                    • 5284
                    Thank you very much, writeup looks very good
                    • R3Z3N
                      • Jan 2011
                      • 3056
                      I had planned on doing the conversion, but ended up selling my S54 build on BAT. I was in talks with Andrew Lidell of the writeup I posted, and he can modify the steering column so that the steering angle sensor is integrated when also using the DSC Speed Yaw/Accelerometer Sensor. Doing so will get you stability control as well as epic ABS.
                      • johnaoshea
                        • Jul 2017
                        • 7
                        No, I still want to eventually but the car had bigger issues than lack of abs - mainly rust and a dying engine. I did end up buying all the abs bits from another e30, putting that in for the time being.
